Old 10-28-2009   #221
Re: Beater 2g
It blew in a spot that was re-welded after the nitrous back fire. It blew on the longest spot on the end tank of the intercooler, have to think its 35ish lbs per square inch and on such a long end tank it can only take so much abuse. My shitty launches and getting a little sideways in 2nd probably didn't help at all either with the way it is mounted.
Old 10-28-2009   #222
Re: Beater 2g
Power was pretty much the same at the same boost as the old FP3065. The HTA comp wheel did spool it a couple hundred RPMs quicker. I think it was hitting 30psi at around 4400RPMs, not bad for a car making this kind of power. We thought we would try more boost and try to make use of the new comp wheel, but it made the exact same boost from 5500 or so on up. We might just be blowing open his wastegate, it only has a .9 bar spring in it and we aren't pushing any boost to the top port. I think peak power was at around 32-33psi, if the boost drop problem is just the wastegate and not something maxed in the turbo, then it would be interesting to see what it would make at 36-40psi.
Old 10-28-2009   #223
DSM-is-LOVE
Dream Motors All Day!
DSM-is-LOVE's Avatar
Drives: 03 Evo VIII
Re: Beater 2g
love the car
just watched the video of it run 10.9 at BIR
2003 Evo VIII
aka Lucy
Old 10-29-2009   #224
At-Least-It's-An-Evo
At-Least-It's-White-Again
At-Least-It's-An-Evo's Avatar
Drives: 98 iVTEC
Re: Beater 2g
nice powah.
'04 Honda Ricer: stock
Old 10-29-2009   #225
Re: Beater 2g
Just curious why you went with the DSM82 vs the DSM86? the 86 is where it's at. Did they put in a full 35R turbine wheel, or leave the 30R wheel on there? That could be your choking point if it's an hta82 comp wheel w/ the 30R turbine.
VERY respectable powerband though, keep having fun with it!
Old 10-29-2009   #226
Re: Beater 2g
It is the only upgrade they offer for the FP3065. All they did was change the compressor wheel.
Old 10-29-2009   #227
Re: Beater 2g
Hrm and here I thought the DSM82/86 were full 35r turbine wheels, but reading their site it doesn't look like they actually are.
Old 10-29-2009   #228
Re: Beater 2g
Sorry to hear about the bad luck, twinkie told me about it.
Next year should be an awesome one for you.
Old 11-14-2009   #229
Re: Beater 2g
Should help save some more weight off the car. Probably wouldn't have bought either of the two things but found good deals on both of them, so why not.
Old 11-14-2009   #230
Re: Beater 2g
Going for that no-so-streetable setup now then? :P That looks uncomfortable as hell!
Old 11-14-2009   #231
Re: Beater 2g
In my mind it will always be a street car, but its probably never been a street car to most. Open down pipe and no a/c since its been running, and after bir I took the heat out and recently with the twin disc it would probably be pretty un-streetable to most, but I don't mind it.
The pro drag seat is actually very comfy, and I think I'll honestly like it better than the stock seat. I'm so damn lanky that my head hit the roof of the car if I sat straight up, and with a helmet on I had to turn my head to the side. With this seat I'll be able to mount it lower and hopefully fix the being too lanky problem
Old 11-14-2009   #232
Re: Beater 2g
A sheetmetal seat won't fix you being a lanky ginger, just help make you fit better :P So no seat cushion at all? Cruising around town won't hurt at all? I'm just a skeptic, sorry. Looks nice though!
Old 11-14-2009   #233
Re: Beater 2g
Nah, I'll rock a seat cushion, just found this thing pretty cheap on craigslist and always wanted one. I'd probably would've gotten a nice sparco/recaro lighweight seat but I'm not that baller, so this will do.
I'll let you sit in it with a cover and I bet you'll say, they really aren't that bad
Old 11-14-2009   #234
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
Re: Beater 2g
It looks PAINFUL! Man talk about hitting a pot hole LOL! Track raced maybe then. With those crazy suits on lol,but man still your BUTTS GONE BE ON FIRE!!!
Old 11-14-2009   #235
Re: Beater 2g
lol, nice find.
I have sat in a bare one for a few mins and they are comfy, but I have heard from a lot that the seat pads are good.
F what anyone says as long as you like it then cool, if not sell it and find something else.
You get some new WG springs yet or waiting till next year?
Keep the stockblock and get the record clearly.
Old 11-14-2009   #236
Re: Beater 2g
Haha I didn't realize they made covers for those, I def would love to try it out! Def nice, I can see those being more comfy.
Old 11-15-2009   #237
Re: Beater 2g
Thanks Aaron! No new wastegate spring yet, thinking about letting it sit for the winter and try and save up to get the thing cagged. I think it'd be pretty cool to go for the record but it'd probably be cheaper to build this motor rather than finding another block. I'm super cheap where I can be tho, so I'll probably just let it buck on a stock block haha.
Old 11-15-2009   #238
Re: Beater 2g
haha, hooray for cheap people!
Old 12-17-2009   #239
Re: Beater 2g
Went to go fill the car up with gas yesterday night after finishing mounting my krikey, and I have to say that spinning instantly when boost hit in 3rd was kinda cool
The cool thing about the way my dad and I made the kirkey brackets is that they are completely removable and utilize stock mounting holes. So for daily driving I can swap seats in no time.
If anybody is buying a steering wheel and hub, DO NOT buy from Crowderscustomizing.com. About a month after I ordered my quick release, hub, and adapter I finally get all the right parts...
I also took out some of the interior wiring like door ajar sensor, washer pump thing, other misc wiring, rear speakers, and the front seat belts saved me a total of 19lbs. Hoping to make it as light as possible while still looking stock besides the kirkey.
I'm trying to think of other cheap things I can do to make it go faster some how, but kinda running out of ideas.
Old 12-17-2009   #240
Re: Beater 2g
^now you are making me cry, all the things you are doing are the things I wished were never done to my car and that I am trying to fix.
I'll be home for the next 2 weeks, maybe I can stop by with twinkie I can usually come up with some crazy ideas when the project is in front of me.
Looks good man.
Tags
quick for a 2g, team ginger
