Build the X 17 56.67%
Old 02-01-2013   #2441
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
You can get a 6266 or 6766 for half the cost of a 6466, so it's probably not going to be that commonly used.
Really?
The 6466 is actually more than both those by double? Or do you mean a lot of people are selling them used for cheap or something? Just confused how the other turbos can be so much cheaper? I am guessing they are all about the same cost to produce.
Old 02-01-2013   #2442
4seasons69
4seasons69's Avatar
Really?
on pte's website a 6466 is 1909.99, a 6766 is 1199.99 and a 6266 is 999.99 so the 6466 is just normally quite a bit more
Old 02-01-2013   #2443
That is awesome, I say do it.
Is there anyone local making good power on a 6466? I haven't seen one outpower a 6266.
There's a guy named Troy on evomn (and here) that had a 6266 fail, when it came back it was a 6466. The car made like 40whp more and spooled about 200rpm later. Pretty sweet
Old 02-01-2013   #2444
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
i like the 6466 idea lol
although your ef4 is probably pretty nasty
2006 WW IX RS 396/404 - SOLD
Old 02-01-2013   #2445
Same boost levels?
Old 02-01-2013   #2446
There's a guy...that had a 6266 fail
That's wierd...
Old 02-02-2013   #2447
That's wierd...
2 of them actually. One lasted about 5 minutes of idling, the other about 500 miles of break in and >10 psi.
http://www.evomn.net/forums/showthre...466-comparison
Old 02-02-2013   #2448
MorningWood
Drives: Evo 8, 2014 Silverado
Me and Josh are both making good power on the 6466's. My car still had a stock intake manifold, throttle body, and no porting on the head, it made 709whp at 38psi on RS's Mustang Dyno. Josh Made over 700 on Buschur's Mustang Dyno.
The reason the 6466's cost so much more is they only come in Ball Bearing, you can get the 62 and 67 in Journal Bearings hence the lower price on the site, when you get up to the Ball Bearing option for those turbo's they close in on price with the 64.
My 64 actually spooled the same as my 62 did, at 35psi it didnt really make much more power. but the 6266 quit making power on my set up at that level (615whp on Ron's Dyno) the 6466 started picking up good power around there so it must have been right in its efficiency range, I ended up being able to make 665whp with 39psi, then it slowed down on making power until I went from kelford 272's to GSC s3's where it made 709whp at 38psi
MorningWood is offline   Reply With Quote
Old 02-02-2013   #2449
bramagedained
bramagedained's Avatar
Drives: EVO IX SSL
My car is at DB getting the fuel system changed some and setup on E98 so we'll see what kind of power it will make all in. Though my stock ported TB and IM will probably turn into a restriction, maybe the M2 cams too, but, none of that is going to get changed.
The 711 at buschur/773 at MAP my car made was done with a tune setup for E70(that was 5 months old at the tme) too.
Old 02-02-2013   #2450
Vassil made 745 on a DSM at DB at 35psi, that is why I ask and there are a few DSMs in that 700-750 range without going over 40psi.
That is the only reason I say that, I have heard that the 6466 and 6766 spool damn near the 6266 in a lot of cases though.
Old 02-02-2013   #2451
Murlo26
Murlo26's Avatar
Sorry to get off the whole 6466 topic Maybe I should've made its own thread, didn't think it would generate enough talk.
Anyway, new parts! Trying to solve my whole crank case pressure deal, this should do it. At the track my oil cap came off, not sure if its from the fact it might be a shitty design or just crank case pressure pushing it off, so I didn't want to risk it and bought these. New oil cap (lost mine) and new catch can with 10AN lines and light weight matching bracket on the other side of the bumper.
Here is an example of it installed:
I'll take more pictures this spring when I put it in with my new fuel rail and new injectors.
Old 02-02-2013   #2452
If a DSM cap is the same style and fits on your car, you are welcome to try my -10AN oil cap.
Old 02-02-2013   #2453
Murlo26
Murlo26's Avatar
I don't think I'd need that. I assume that is to connect to a catch can? My valve cover has 2 ports already.
Old 02-02-2013   #2454
What's that 2nd bracket for?
Old 02-02-2013   #2455
Looks like it actually replaces the mount for the front crash beam. No wonder it's so beefy
Old 02-02-2013   #2456
Murlo26
Murlo26's Avatar
I'll show pictures later, the second bracket is the mirror image, just not a catch can on the other side, weight savings basically.
Old 02-03-2013   #2457
Yes it would need to be connected to some kind of catch can, well I'm getting rid of it and I didn't know if you wanted more ports.
Old 02-03-2013   #2458
Murlo26
Murlo26's Avatar
Here are a few more pics, its part of the front crash beam like Scheides said I believe.
Yea I don't think I will need any more ports, thanks though man
Old 02-03-2013   #2459
So are there any provisions for providing vacuum to the oil can?
Also how on earth is that 'easy access' for draining? I guess if you have no undertray?
Old 02-04-2013   #2460
Murlo26
Murlo26's Avatar
No provisions for vacuum on this. And its just as easy/hard as my current catch can setup, which sucks to drain lol. My current one I have to basically take my bumper off to do. This I think you can pull the undertray and drain, maybe 20 mins of dinking around, not so bad.
Tags
