Build the X 17 56.67%
Old 03-18-2013   #2601
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
[QUOTE=cmspaz;426027][QUOTE=Murlo26;426021]YOLO!
Remind me to punch you in the dick the next time I see you.
hmmm, pass?
Old 03-18-2013   #2602
cmspaz
Walls need hugs too
cmspaz's Avatar
LOL
Originally Posted by Trogdor
Old 03-18-2013   #2603
FWIW I run a .91AR
Old 03-18-2013   #2604
I just got a new favorite saying at work!
Old 03-18-2013   #2605
Murlo26
Murlo26's Avatar
FWIW I run a .91AR
Is yours divided? Where do you hit 20psi?
Old 03-18-2013   #2606
URV8SUX
URV8SUX's Avatar
I ran a 1.32 divided housing on a 6765 few years ago it made 30psi by 6500rpm.
If you looking to get the most power of a 67mm there is better options than the PTE 6766.
Old 03-18-2013   #2607
Divided T4 yes. Borg Warner 61mm. Never ran 20psi through it yet. Hope to cross that road in the next few months. AR is just a ratio though, so it's kind of hard to compare different manufacturers housings just by the AR number alone.
Here is old post of mine showing some back to back tests on a 2.5L Subaru I believe, comparing two different BW turbos (60mm and 63mm) with two different exhaust housings (.91 and 1.0). You can see why I chose the .91.
http://www.mitsustyle.com/forums/sho...1&postcount=62
But again, these are BW housings so not really apples to apples with PTE stuff. And remember AR is a ratio, there's more to it than just that number.
Old 03-18-2013   #2608
4seasons69
4seasons69's Avatar
He's going to be running a 62mm. But you said this in my build thread and failed to produce any examples when I asked. Sure there are some that out flow 6766 but most 67mm turbos out there cost more.
The a/r is very subjective. Halon let me borrow his bw to test fit it on my talon. His exhaust housing is a .91 and when comparing it to the .98 housing off of my gt4294. Even though the a/rs are pretty close Halon's seemed quite a bit smaller.
I went with a 1.32a/r on my 6766 and it also looks smaller than the .98 of the gt42. Even though the a/r is quite a bit larger on the 6766 I can't imagine it will spool any slower that my gt42. I guess we'll find out soon.
Old 03-18-2013   #2609
Murlo26
Murlo26's Avatar
Yea I wouldn't go with a 6766 if I was going that big, next step is the 6466 for me if I ever get there. The 6266 should keep me happy for this season and hopefully all of next. Plenty to do to the car that doesn't involve turbos after this upgrade.
Old 03-18-2013   #2610
URV8SUX
URV8SUX's Avatar
Well since you failed to ask in your thread but now you did in this thread here you go!!!!
EXAMPLE#1 http://store.forcedperformance.net/m..._Code=Turbo-FP
EXAMPLE #2 http://www.full-race.com/store/borgw...sx3-turbo.html
EXAMPLE #3 http://www.precisionturbo.net/turboc...d-OGS-SFWD/500
Also BW has an 11 blade 67mm rated at 1000 or 1050 just can't find it......
Thanks!
For what its worth....
PTE 6765 with 1.32 housing at 34psi made 719whp @DB
BW 67mm with 1.10 at 35psi falling to 32psi made 785whp @DB
Same set up different turbos.
Sounds good!
Old 03-18-2013   #2611
4seasons69
4seasons69's Avatar
EXAMPLE #3 http://www.precisionturbo.net/turbochargers/class-legal/details/Class-Legal-Turbocharger---PT6785-CEA®-for-MIR-Super-Street--True-Street-and-OGS-SFWD/500
Thanks!
Thats some good info! I'd like to see 700@db if I can. We'll see how the 6766 does. If I don't like it I'll run it this summer and go a different route next winter
Sounds good!
Actually I did ask in my thread. I was looking at that bw and fp. Those are gt42 framed sized turbos. I went with the 6766 based on boostin performance's recommendation to not go with a turbo that large for my goals for my car. They recommended the fp hta3794 or the 6766 (yes the 3794 also out performs the 6766). The 3794 is $2500. that bw and fp hta4294 are $1500 and that other pte one you posted is almost $4k. I went with the 6766 because it was $1050 new.
Old 03-18-2013   #2612
4seasons69
4seasons69's Avatar
Sorry for the mini thread jack! I can't wait to see what your car does on the 6266!
Old 03-18-2013   #2613
bramagedained
bramagedained's Avatar
Drives: EVO IX SSL
The 6466 sure fit nice behind the motor on the 3Dx Evo at Tx2k...
Left as gigantic image for effect.
Old 03-18-2013   #2614
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
bigger pic please
2006 WW IX RS 396/404 - SOLD
Old 03-19-2013   #2615
cmspaz
Walls need hugs too
cmspaz's Avatar
Walk into my cube and say that again... I dare you.
Old 03-22-2013   #2616
Murlo26
Murlo26's Avatar
Well, sounds like the new 6266 showed up today at MAP They are mocking it up now on a test engine outside the car. It is indeed the 1.0AR housing and after hearing this from Aaron at English Racing I feel pretty good about not going with the .84 A/R:
6466 testing (not quite what you are asking but similar)
2.3 VIII with a SMIM made 22psi at 4500 with a 1.15 vs 13psi at 4500 with the 0.82 T3
Volvo 2.5L we saw 34psi of backpressure at 27psi with the 0.84 TS. A more efficient Evo X would be even worse. Currently that same turbo went on a 2JZ (3.0L) in the same car with the 1.00 housing and was 13psi backpressure at 18psi of boost before we had to stop because of an injector issue.
It would be my opinion that the 1.15 is the best choice but since you are wanting more response than peak power I'd start with the 1.00. Worst case is you have to buy a new housing and then retune.
So he thinks even the 1.15 for the X but sounds like the 1.0 is a better choice for sure than the .84. So game on.
Old 03-22-2013   #2617
4seasons69
4seasons69's Avatar
Good choice! Can't wait to see your results when it's finished!
Old 03-22-2013   #2618
Mark Leasure
Mark Leasure's Avatar
So why a T4 manifold on a 6266? I had good luck with the vband on mine, makes good power and spool is responsive, just my 2 cents. You will like the new power capability!
www.maperformance.com
Old 03-22-2013   #2619
Murlo26
Murlo26's Avatar
I debated vband, the AMS kit is vband and is pretty badass. But honestly from what I have seen the t4 twinscroll is even a bit better for response while still being able to dish out the top end.
Realistically, this all came together with the opportunity to work with MAP on making their new t4 twinscroll kit, so that is why I jumped onto it this year (was going to wait for another year of succesful motor running) but it was a good opportunity to jump into the non stock frame stuff which I have wanted for a while now.
Old 03-27-2013   #2620
Murlo26
Murlo26's Avatar
Updates:
Looking good
Tags
