Build the X 17 56.67%
Old 04-03-2013   #2661
I'm sure it feels awesome up top, but that low and mid leaves a lot to be desired.
Old 04-03-2013   #2662
Boost creep is a pain in the ass. I have to deal with this kind of shit a lot with the cold weather here, which makes boost creep much worse. The VF52 Subaru's get it bad with a catless downpipe for half the year here, they are often fine in the Summer, then it gets cold and then you can't keep the boost from going over 20psi on it's own. With the newer more efficient big turbos nowdays, it happens easier since the turbos just want to make boost and you end up having to set a low revlimiter if running on pump gas. I have an Evo 8 here now with a 35R on it that boost creeps to 30psi no matter what and it's a pump gas car. If you run less ignition timing to try to keep it from knocking, then the boost creep gets even worse.
Old 04-03-2013   #2663
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
They were trying to run wastegate boost on this car that I posted which is 15psi. It's a pump gas car and the single wastegate got over run. He said it spiked to 34 psi at 7k rpms.
So it was more of a funny picture, but it looks like the turbo is pretty potent on a similar motor, I am excited.
So the torque is low down low just because it starts out at 15psi.
Old 04-03-2013   #2664
Wow, that's crazy. I know Cobb had to add a 2nd external wastegate to Chkmgnt's car for this very reason.
Old 04-03-2013   #2665
Murlo26
Murlo26's Avatar
Glad I have twin comp gate 40's going on this thing, that is all I am saying!
Should be interesting...twice the wastegates means twice the epic ear splitting dump pipes!
Old 04-03-2013   #2666
Have MAP recirculate them for a more pleasant WOT tone.
Old 04-03-2013   #2667
Murlo26
Murlo26's Avatar
Hmmm, nah....
I like the noise And the extra power. If it gets annoying I will have them modify it later.
Old 04-03-2013   #2668
I don't buy the extra power statement [assuming a properly sized and designed exhaust system], but to each their own
Old 04-03-2013   #2669
Murlo26
Murlo26's Avatar
I dunno, I have seen plenty of results showing gains by switching from a non dump to a dump and picking up significant power.
If I didn't do the dump I would think I'd want a 3.5" exhaust at that point.
It's what I am getting for now so I will go with it.
Old 04-03-2013   #2670
93gtpeater
Drives: cbr 1000rr repsol
Murlo needs to save his money so he can buy a corvette in a couple months.
Old 04-03-2013   #2671
Group buy on C7's?
Old 04-03-2013   #2672
Murlo26
Murlo26's Avatar
Group buy on C7's?
Hmmm, I'd have a tough time choosing between the c7 and c6 z06 honestly. I think I'd go z06 as the aftermarket is there for it.
Old 04-03-2013   #2673
Murlo26
Murlo26's Avatar
Starting to really get excited now!
Can't wait to see this in person, looks beautiful.
Old 04-03-2013   #2674
4seasons69
4seasons69's Avatar
Looks good!
Old 04-03-2013   #2675
Looks awesome! Nice fab work MAP.
Old 04-03-2013   #2676
bramagedained
bramagedained's Avatar
Drives: EVO IX SSL
Two WGs is definitely the way to go.
My car will creep pretty bad with just one WG.
Old 04-03-2013   #2677
4seasons69
4seasons69's Avatar
My car also creeps really bad with only one wastegate. I would like to add a second but I'm not too worried about it at this point though
Old 04-03-2013   #2678
Murlo26
Murlo26's Avatar
Anyone know part numbers to get new OEM pieces for the following:
I am missing this stupid cap here for the AC line (i think)
My terminal cover is cracked and doesn't stay on well anymore.
I was struggling to find these on mitsu parts .net, any help would be nice.
Old 04-04-2013   #2679
call dealer?
Old 04-04-2013   #2680
PM Trogdor, I'm sure he can cruise over to the parts counter and have them ordered for you.
Tags
