Build the X 17 56.67%
Old 04-20-2013   #2721
I hate that stupid o-ring. Bad design imho, rips every time.
Thwarted by a battery eh? Geez. MAP has a lightweight unit you should try out:
http://www.maperformance.com/tomioka...i-tr-b600.html
It hits 20psi in a nice spot but torque is still pretty low and slowly climbs through the pull, that's crazy. My car (and yours on ef4 probably) made ~400wtq (dynojet) at 4500rpm so this setup is a good 100wtq below that there....maybe with some tuning it'll come back, but I think that's where the really big snail is obviously showing itself...the power up top is gonna be hella!
Will be curious to see how you like it on the street at this power level and then you know, what breaks when you start running some more boost
Old 04-20-2013   #2722
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
I am going with the odyessey pc925 i think, putting some weight back on but a better/stronger battery with more reserve.
I am not sure about the down low yet, keep in mine pull wasn't started til after 3500 rpms and it got up in there in 1000rpms. We couldn't get into down low very well with the fueling problems down there.
I think it will be better with more boost and some actual mivec and tuning etc.
This is still very preliminary It feels like it hits hard down low still.
Old 04-20-2013   #2723
Amazing awesome how early the power comes on. Can't wait for 35psi pulls.
Old 04-24-2013   #2724
Murlo26
Murlo26's Avatar
Me either, 35 will be ripping I think!
Just bought a new boost gague to match my AEM wideband. Going to install that this weekend when I move all my gauges up top to my new gauge pod.
Also ordered the PC925 battery, hopefully its here friday or monday at the latest.
The AMS battery is a Genesis 16EP, which is for snow mobiles or something. So its way undersized, basically just for drag racing etc. I think I made the right choice moving up a bit, more weight but worth not struggling to start if it works.
Going to head over the knoxville's tonight for install on his G8 and hopefully some tuning on my end too if Jon is available and my car starts.
Old 04-24-2013   #2725
Murlo26
Murlo26's Avatar
Yea, I think torque might be lagging behind for sure, but spool isnt' I don't think. I think this setup, if started at the same RPM will be the same time or better than the EF4.
It looks like I hit 400wtq on the EF4 at around 4200rpms on the last setup.
but i also started that pull 600rpms sooner.
I think I will loose a bit down low but I think with MIVEC tuning and some timing that it won't be too bad. This kit so far looks impressive, can't wait to get more results.
Old 04-25-2013   #2726
Murlo26
Murlo26's Avatar
Jonny boy was busy bee tonight, no tuning.
Tried again for a spool graph, still breaking up from lean ness I think.
Here is my try...if I started too low it wouldn't give me a full clean run.
Here is starting higher, revving out Still wastegate.
Seriously can't wait to get this bitch rolling. Feels nasty up top.
Old 04-25-2013   #2727
I haven't seen the SD stuff for the X, but the VE has got to be way out of whack around 4000rpm. Keep going, don't blow it up. You'll get it.
Old 04-25-2013   #2728
Nice, going for some power I see.
Old 04-25-2013   #2729
Full boost at 4100 isn't bad at all. Looks promising and can't wait to see it running good!
Old 04-25-2013   #2730
Murlo26
Murlo26's Avatar
zero knock through any run i have logged so far, its running very strong so far. Just shitty down low. I agree, i think the VE (MAP tables) and maybe fuel calibration table need adjusting down there as the new turbo just flows so much more, the car felt pretty beastly with wastegate pressure, liking it so far.
Maybe
I think it will potentially be even better with mivec and proper fueling etc. I wasn't able to really get into down low as the fueling is so off down there. Once I get fueling figured out, the car should spool by 4kish I think.
Old 04-25-2013   #2731
93gtpeater
Drives: cbr 1000rr repsol
So are tuning the car are you going to let Shane tune it.
Old 04-25-2013   #2732
4seasons69
4seasons69's Avatar
Looking good! Can't wait to see what it does when you get everything sorted out!
Old 04-25-2013   #2733
Murlo26
Murlo26's Avatar
Neither, Jon Drenass has been tuning the car. He's from california, used to own HBspeed, then worked for Cobb when Cobb bought him out now owns his own shop again.
I have been using Jon since last Spring when I wanted to switch to SD (hybrid mode).
Old 04-26-2013   #2734
Murlo26
Murlo26's Avatar
Well, keep in mind, very early stages of tuning, sorting out bunches of stuff. This wasn't on a flat road really either, uphill a tiny bit, but i wanted to show spool. We are fighting some surge too right now, mivec adjustment coming.
But the turbo hits really hard, spools in less than 1000rpms.
Sad news tonight...
tactrix broke Sending to Colby to fix tomorrow, going to try and borrow one in the mean time, but might delay tuning some. The car is beastly now. Destroyed a modded cobalt SS...he pulled up on my while logging and the car was feeling good so i ran him, but bus lengths on him, 2-3-4 run. The car broke my 275's loose from 2nd to 3rd, traction control kicked in.
Anyway, spool is looking good and we are working on getting load down to where we want it so I can run higher boost later.
To be continued....
Scheides or anyone, can I borrow a tactrix 2.0?
Old 04-26-2013   #2735
Murlo26
Murlo26's Avatar
double post somehow.
Old 04-26-2013   #2736
Tehehodi STILL has mine. Make him give it to you LOL
Old 04-26-2013   #2737
Murlo26
Murlo26's Avatar
Text him for me, I need one this weekend to log/tune with. Wanna get this bitch rolling!
Old 04-26-2013   #2738
You can borrow mine Murlo, txt me and we will hook up.
Old 04-26-2013   #2739
Murlo26
Murlo26's Avatar
Sweet, thanks Scheides.
Old 04-26-2013   #2740
So he is tuning this remotely?
Tags
