Old 09-09-2011   #261
blackawdtsi
Drives: 2G DSM
Re: Big Brown's Automagic - The last episode in my DSM story.
I doubt you guys will need 4th. At 7200 rpm that's 132. If you guys do bump the limiter, I'd raise it to 7500 before shifting even on an auto.
Old 09-09-2011   #262
Nice update! Looks like you're having fun with it and keep making it better. Keep up the good work dude, I'd like to see this thing make a pass
Old 09-09-2011   #263
munchgsx
munchgsx's Avatar
Drives: 2004 Corvette M6 F45
True but idk if 7200 is realistic power wise yes. May have to shift way earlier. It feels good, just do not have the passes/numbers to prove its good.
Old 09-09-2011   #264
Lets not turn this thread into BS speculation,
the car will trap over 100 and that means I will need to use 4th. End clutches will be ordered this winter unless I 1. drive the car enough in the next 2 months or 2. know 100% I'm going to need to use 4th at the track.
Old 09-10-2011   #265
Made some more progress today, I decided to relocate my AFPR and hookup my electric fuel pressure gauge.
Working out how long to make the line:
ADD cut in and I pulled the battery out, stock battery in stock battery tray sucks its always in the way and just huge.
Samantha and I both drive hondas, which we all know sport small batteries so I attempted to steal one, first out of my car, but its placed between the strut tower and the firewall, so no-go on that one, then I looked at her car and its right up front with enough room to fit a larger one in.
DSM battery in honda:
Random metal I had laying around that I formed to hold the battery above the transmission but in a lower position than stock.
All done with those jobs, AFPR & battery relocation complete:
Then I decided to mount my new coolant overflow, so that I can run at the track. It is NHRA legal as it will hold over the required quart capacity.
I bought an oil catch can from ebay and plugged the ports on the top of the can, i then put a barb in the bottom and used it as a coolant resevoir.
Sorry for the shit pic.
Old 09-11-2011   #266
Looking good BB!
Old 09-11-2011   #267
Thanks man, the coolant overflow isn't the best looking but its on a budget.
Old 09-11-2011   #268
blackawdtsi
Drives: 2G DSM
http://www.youtube.com/watch?v=KgASi...eature=related
Do it.
Old 09-30-2011   #269
Ok, feels like a long ass time since the car has been rolling.
But I rebuilt the driveshaft and boy does it feel good.
I also swapped out stock shit rear motor mount for a prothane one from the man known here as HALON!!!, thanks dude made a bigger difference than I thought and it feels good (on me).
What else? hmmm Oh I installed an end clutch kit aka 4th gear clutch kit, there were signs of burning on the stock one but not too bad, this kit should be good for the power that i can throw at it with this turbo.
So once I got all that installed I had an issue with the car blowing MPI fuses, turns out my sweet fuel pump install had a short life, somehow the bolt going thru the positive stud/bulkhead thing wore thru to the sending unit and was grounding itself out.
Thanks for 93GTPeater here for saving me with one! He also gave me his stock driveshaft because mine had a bent yoke in the middle. I love this guy.
I also fixed my power steering leak and ended up replacing the alternator, old one finally couldn't take anymore PS fluid bathing it.
So tomorrow I will be attempting to achieve my goals of 11s, after driving the car all week, I don't know if it has it, but there is only one way to find out.
Old 10-01-2011   #270
Going to rockfalls tomorrow? See you there most likely.
Old 10-01-2011   #271
Good luck man!
Old 10-01-2011   #272
If you run an 11, I best be getting a text!
Old 10-01-2011   #273
Constant_Project21
Constant_Project21's Avatar
Drives: E36
Do work. Good luck man, glad to see youre getting a pass in this year!
Old 10-01-2011   #274
Well I made it to the track and back home!!!
First pass ever with the automagic:
I was so fucking pumped I was ready to come home and drink the rest of the day, but Nick didn't get it on video, he said he thought I was just gonna take it easy since it was the car's first ever pass.
I then followed it up with a 11.45@119 and then I tried to get a bit more competitive with launching.
However the car had enough, and I couldn't get it to stall anymore, so after messing with the tune and some other things I called it quits and came home.
A giant thanks to everyone that has helped and encouraged me so far. Thanks to Nick for coming out there with me too.
Old 10-01-2011   #275
Constant_Project21
Drives: E36
Awesome! Got your 11!
Old 10-01-2011   #276
Congrats on hitting your goal first time out!
Old 10-01-2011   #277
carltalon
carltalon's Avatar
Drives: 98 Eclipse GSX Auto
Congrats. Tens or bust for next year.
11.35 @ 120mph
Old 10-01-2011   #278
19TsiAwd90
2stepadepaaadepaaadep
19TsiAwd90's Avatar
Drives: myself crazy
sounds like a blast awsome build!
Originally Posted by 311evo
Old 10-01-2011   #279
Totally awesome. Auto dsms rock
Old 10-02-2011   #280
Good work dude. Any plans to either make more power, or lighten that sucker up and go for 10.99
