Closed Thread
Old 08-05-2006   #281
Re: Finally getting stuff done on our cars
Originally Posted by JET
I really doubt the turbo's are maxed, 392 whp for each 50 trim shouldn't be stressing it too much. The IC's though, I am sure they are totally maxed. Good luck at the track!
I can't get any more boost out of them period. I'd like to see a 1.5L dsm make 392awhp on a 50 trim. The intercoolers don't help the cause, but I really don't feel like fucking with a fmic on this setup as the turbos will not produce the power levels I want.
niterydr is offline
Old 08-05-2006   #282
So what did you run today?
TheBlizzard is offline
Old 08-05-2006   #283
Bigger, shorter pipes, smoother transitions, a 110mm TB and 3" downpipes = 50 more hp.
FattyBoomBatty is offline
Old 08-05-2006   #284
Damn, that's some serious powah, especially considering the reading is much lower than the dynojet numbers I'm used to. If you can get that thing to hook and shift, it should be an animal, even at 4800 lbs.
Goat Blower is offline
Old 08-06-2006   #285
That doesn't make any sense at all. Air + fuel = power. The size of the engine will determine where the power band is at, but not how much power the turbo is limiting you to (although the engine may limit you). This is simplified, but that is what the equations boil down to.
There is obviously a bottleneck in your system, but the turbo's aren't it. Either that or the VE of your engine sucks, which I doubt. The HP could end up being limited if the engine was too large for the turbo, but not if it is too small like you are saying.
JET is offline
Old 08-06-2006   #286
You have to remember that would be like 460+ per turbo on an AWD or FWD Dynojet and Josh is running internally gated Mitsu versions, which aren't going to perform as well as a normal T3/T4 50-trim turbo.
Shane@DBPerformance is offline
Old 08-06-2006   #287
2)I wanna go single next year, I am tired of the lag and heat, time to look at gt42's.
Josh, does the 6-speed tranny have shorter gears? You have the 5-speed right? The extra long gears would hurt spoolup and make it much harder to stay in boost between shifts.
Old 08-06-2006   #288
Shotgun!
Totenritt
Shotgun!'s Avatar
There are a lot of shortcomings in the setup. I think he has done pretty well for what's gone in and how fast it came together. A 6 speed would help things and so would real intercoolers. But given it's been pushed more than driven, lets drive it and have fun for a bit. Summer is almost over anyway.
Shotgun! is offline
Old 08-06-2006   #289
The real question is what did he end up running at rock falls on Saturday!
A//// Guy is offline
Old 08-06-2006   #290
Ahhh, sorry. I didn't remember them being internally gated. That will hurt the performance a fair amount. I just didn't get his reasoning behind why the turbo's were maxed out.
JET is offline
Old 08-06-2006   #291
tim
tim's Avatar
Ahhhem, I am guessing things didnt go as expected?
tim is offline
Old 08-07-2006   #292
Hopefully nothing bad happened. It really sucks to put all that time and effort into it and have something happen.
JET is offline
Old 08-07-2006   #293
The six-speed trannies also come with the mucho expensive xfer case, the 5-speed setup is much cheaper to fix and apparently is more robust. Just ask Matt Jannusch.
Old 08-07-2006   #294
Yeah the internal gates are really killing it. I might try to unplug the wastegates to try more boost as I think they are getting popped open.
The sidemount intercoolers are heatsoaking at these higher boost levels, they work great for pump gas, probably up to about 550awhp I'd imagine.
Car runs great, just I have a bad 2nd gear syncro. Best pass was a 11.45@135.xxmph off the trailer, no nitrous. I babied the 1-2 and spun a 1.87 60' on that one. I turned on the nitrous the next pass and all it did was make me consistant. The car was down on power the rest of the day (I couldn't get the heat out of the huge cores, once it heatsoaks its over). Off the bottle it gained around 35mph from the 1/8 to 1/4, on the bottle 41mph, consistantly. So I know its gaining power, I just need it to hook up at the line and get the 1-2 shift clean (new syncro). I didn't get a clean shift the rest of the day, ran a bunch of 12.0-12.2 at 125-131mph. However it was a good day because I learned how to get consistant 1.73-1.78 60's and keep it straight in 1st gear, I'll get some tires on there and a new syncro and be golden!
Its all working out bugs, and thats what I do. I just hate making baby steps with parts that I know are holding me back. I am going to give it one more trip to the track on the current setup (hopefully with a t-case housing and sticky tires, and a syncro) before I start to sell/switch out components.
niterydr is offline
Old 08-07-2006   #295
Nice runs!! Its great that its running well and putting down consistant times! Just wait till the air temps are in the 50-60 degree range, that should help.
Old 08-07-2006   #296
LMAO, i smell new setup!! Peter hit it on the head, wait till sept. when the temps are much lower. Just to think at night on the street the ambient temps in sept. will be 40-50F
turbotalon1g is offline
Old 08-07-2006   #297
niterydr is offline
Old 08-07-2006   #298
That's it?
AJ is offline
Old 08-07-2006   #299
Not bad for 202 dyno runs.
Old 08-07-2006   #300
EvilEvo
Sorry to hear the car still doesnt run right. It really sucks when you spend all that time and money on a car and it still cant even make any decent passes
Could you scan in one of the whole timeslips so I can compare some of mine to it and see where your car is hurting?
-Tim Russell
EvilEvo is offline
Closed Thread
