Old 06-02-2013   #301
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Re: 2G auto S/A daily
Got some more stuff done today. Would of got more done but the lawn mower was f'd so I had to fix that do I could finish cutting grass.
Anyways. I got this stuff done
Intake manifold is in
Re located coil under intake
Exhaust mani
Made a push lock oil drain
Ran the oil lines for the turbo
Axles and t-case are in
Bolted torque converter to flex plate
Installed battery on k member
Oil cooler
Relocated fuse box
Pretty much what's left is put the wiring harness in and cross fingers it starts. I need an extra pair of eyes though to watch for leaks and whatnot. So once a friend is available for a few hours ill start it. Goal was today but not gonna happen.
Old 06-02-2013   #302
carltalon
carltalon's Avatar
Drives: 98 Eclipse GSX Auto
It's getting close. I could maybe come help you setup a base tune and get it started some day this week. I will new to get a lifter from you anyway.
11.35 @ 120mph
Old 06-02-2013   #303
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Yeah if we shoot for like Thursday/Friday I should be ready as I plan on not working Wednesday so ill have all day to button stuff up.
Old 06-05-2013   #304
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
So stupid me installed the 5 speed drivers front after telling myself a 100 times that make sure you install the auto one. Sure shit went to bolt the carrier bearing to the block and noticed the shaft barely in the trans. So lost some time today but I got everything out now just have to put it back. Not a huge deal but meh...
I got the harness in last night but have to loom it now so I know where things go and make it look uncluttered. Hard to do though as there's a ton of stuff uner the hood.
Here's a pic though from a few nights ago.
I ended up having to work tomorrow so I'm gonna tackle a lot of the stuff tomorrow night and hopefully turn the key sometime Thursday.
Old 06-05-2013   #305
Woot!
Old 06-05-2013   #306
Looks super clean Nick!
Old 06-05-2013   #307
blackawdtsi
Drives: 2G DSM
The pictures really can't show just how nice this beast looks.
Old 06-05-2013   #308
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Thanks guys. Ill just be glad once its done and finished.
Tom/Aaron ill take ya guys up on the offer for help this weekend if your not busy.
Old 06-05-2013   #309
Ahh, I wish I had this weekend off, I wanna see it run!
Old 06-05-2013   #310
4seasons69
4seasons69's Avatar
I think I should be free Friday after work, later Saturday evening, or Sunday if you want some help
Old 06-05-2013   #311
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Yeah just send me a text. Hopefully I get it to the point tonight where all I have to do is turn the key.
Old 06-07-2013   #312
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Axle and t-case back in
Turbo back exhaust installed
Valve cover is back on
Raised the car up a few inches and set her back on the ground.
I dumped 4.5 qts of rotella 15 40 into int tonight and a bottle of zinc additive so that's done to.
Just need to put the wide band in, and redo my power wire coming from the fuse box and should be good to go.
Thanks Carl for stopping out and setting up a base so I can start this thing with a little more confidence now.
12's here I come!!!
Old 06-07-2013   #313
carltalon
carltalon's Avatar
It sounds like you should be able to start it up tonight. Thanks for all the parts.
11.35 @ 120mph
Old 06-07-2013   #314
97gsexx
97gsexx's Avatar
Drives: 97 talon
This is one of the cleanest 2g's I have ever seen. Those wheels are sick! Looks great!
Old 06-07-2013   #315
Woot!
Old 06-07-2013   #316
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Off work in a few hrs and gonna run to flake and get e85.
Should be able to get a few miles on this weekend barring any setbacks.
Thanks 97gsex
Old 06-07-2013   #317
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Well that was fun. (w/ Tom and Joel)
Not sure how but it started on fire.
Old 06-07-2013   #318
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Oops double post.
Old 06-07-2013   #319
Everythign ok?
Old 06-07-2013   #320
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
No damage somehow. Definitely a holy shit moment. Toms got a pretty sweet pic.
After the fact and it happening all I could think of was quoting FF and yelling "naaawssss" I cause I thought it would blow up. Lolz
On a side note we did get it started and it sounds beast! It's just to bad there's an oil leak so we stopped for the night.
Also if you own an auto and it doesn't start make sure you check the neutral safety switch before you go digging through a bunch of ignition wiring and repays.
Thanks Tom for getting it started
