Old 12-28-2008   #321
Re: My Winter Upgrades
Nah I didn't, sorry.
Old 12-30-2008   #322
I have another head that I just got back from the machine shop, it is just like brandon's. I'll try and get a pic of it tonight before it goes back on the car. Gratz on getting it running Brandon!
Old 12-30-2008   #323
Thanks Jet.
My newest problem is a stupid problem to even have, but is kicking my butt. I can NOT get the Xfer Case fill plug out. I finally had to resort to vise grips, and still nothing. It's soaking in PB Blaster now, sucks...
Old 12-30-2008   #324
Did you already remove the drain plug?
Old 12-30-2008   #325
I had already removed the entire Transfer Case to be able to get my oil pan off. It's empty.
Old 12-31-2008   #326
Try hitting that fill plug with a hammer a handful of times..right on the face of the plug. This happens a lot with trannies and diffs and such, and that's what i do at work to remove them.
-A. Swift
Old 12-31-2008   #327
You need some HEAT, mon!
Old 01-06-2009   #328
Plug is out. XFR Case is filled. It think she's ready to rock! Now I just need MNDOT to not salt the roads for awhile so I can just take it on a nice slow test drive around the block and make sure the speedometer works again
http://www.youtube.com/watch?v=ztwqksCLnyk
Old 01-06-2009   #329
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
Woot! Glad to see your back.
-1990 Mitsubishi Cyborg 4WD-
Old 01-06-2009   #330
Why not just put it up on jackstands so that all the tires are off the ground, put it in gear and see if the speedo works?
Old 01-06-2009   #331
Because... ...I never thought of that Good idea, I might try that!
Although I do still want to take it around the block to help the get the rings seated.
Old 01-07-2009   #332
polishmafia
Smells like cat poop
polishmafia's Avatar
Great to hear it, Brandon!
Old 01-07-2009   #333
Its alive!! NICE
Old 01-07-2009   #334
Do you always wear you PJ's when working in the garage?
Old 01-07-2009   #335
Didn't wanna get the interior all greasy, so got outta my grubby clothes and changed into my PJ's and then started her up
Old 01-07-2009   #336
lol "this is for those 'other' folks to enjoy"
-A. Swift
Old 01-07-2009   #338
-A. Swift
Pretty sure he said 'southern.'
Old 01-07-2009   #339
Yeah I did.
Old 01-07-2009   #340
Put it up completely on jack stands and "drove around" in first gear with all the wheels off the ground. Speedometer works. I'm thinking maybe the CAS got wet in the car wash last fall which somehow caused the RPM gauge to bounce all over. I wonder if a CAS not putting out the correct signal could cause that, and could also maybe somehow have caused the carnage that took place moments there after.
