Old 02-16-2011   #321
Re: GheyrodX - bigger, fatter, gheyer!
I just off the phone with them again and they're saying they filled the fluid to the proper level, cleaned everything up, and it appears all seals are intact and the fluid was coming out of the top case breather tube. After test-driving the car they're saying everything is functioning OK and not making any whining or howling noises. A case has been opened with Mitsubishi with everything documented in case a problem arises in the future, but for now they're saying the car is ready to go. I'll of course listen for any noise very carefully and if I don't feel it's 100% I'll be leaving it at the dealership.
Old 02-16-2011   #322
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Sweet! No down time ftw!
I am going to see if MAP can check my levels while my car is there...better safe than sorry.
Old 02-16-2011   #323
Definitely, this is beginning to sound like more common of a problem. One up there and two down here that we know about...so far. Easiest thing to do is just remove the fill plug and let any excess drain out.
Old 02-16-2011   #324
Murlo26
Murlo26's Avatar
I'm almost at 30k on mine though...i am guessing it would've happened by now if it wasn't right.
Old 02-16-2011   #325
Most likely. You're definitely due for a fluid change though. Mitsu's interval is 30k normal and 15k severe.
Old 02-16-2011   #326
Murlo26
Murlo26's Avatar
Yep...total fluid change is on my spring time list.
Old 02-16-2011   #327
I was planning on changing my transfer case and rear differential at 15k miles...my car almost made it!
Old 02-16-2011   #328
Murlo26
Murlo26's Avatar
So they would've covered this under warranty if it needed it? Or if it still will need it? (which hopefully it won't)
Old 02-16-2011   #329
simulatedwood
Drives: 08 Evolution X
Mitsubishi FTL ! Don Herring FTW ! Thats great news for you, Stopping the car and having it towed likely saved you from further damage from heat expansion. Awesome!
If i only I could say the same good things about our dealership here in town. Fuck Brookdale.. you bunch of assholes!
Whew ..feel much better.
Shawn
Old 02-16-2011   #330
So transfer cases howl and whine when fluid comes out? That is odd...
So nothing was replaced as well? Im guessing you just stopped the car because of the noise?
Old 02-16-2011   #331
Yes, it appears so.
Odd indeed, but they have test-driven it and say it's making no abnormal noises. I will test-drive to confirm before taking it home. It is good knowing everything was documented (including the factory drain/fill plugs being untouched since the factory) in case something occurs down the road...at least these things have 60k mile warranties.
Old 02-16-2011   #332
Originally Posted by simulatedwood View Post
Don Herring FTW !
I definitely have to agree; so far they've been great regarding warranty and mods. I hope the car is fine as they claim and I have no further issues to deal with.
Old 02-16-2011   #333
Good luck
Old 02-16-2011   #334
Wonder if it'd be worth it to "not" have MAP check it, and bring it to the dealer to check it as MAP would break that factory paint seal thing Chris mentioned by checking the fluid level. I'd think a break in that paint would give the dealership an out to say "it's been worked on, we can't guarantee anything anymore". Just a thought.
Old 02-16-2011   #335
I just got home and the car seems fine. Any drivetrain noise it's making I would say is ordinary for an Evo with driveshaft and rear diff bushings. Don did reconfirm that everything has been documented and Mitsu corporate has been notified just in case something occurs later on.
Old 02-16-2011   #336
mlomker
*Resting In Peace*
mlomker's Avatar
murlo has a built motor and a six puck...Brookdale isn't covering shit. lol.
Old 02-16-2011   #337
All the guys at Don Herring asked me about mod-wise was to make sure I was still on the stock clutch, they said as long as the clutch was stock then it wouldn't be a problem.
Old 02-17-2011   #338
Murlo26
Murlo26's Avatar
Yes, Kracka you put F350 BBQSAUC under your avatar I approve, lol.
Old 02-17-2011   #339
LOL I didn't do it, but I'm guessing Scheides did!
Old 02-17-2011   #340
Hahahahahaha love it!
