Old 06-08-2012   #341
GsXtUrBo98
GsXtUrBo98's Avatar
Drives: 98 GSX, 04 is300
Re: GsXtUrBo98's 2G project thread
Yes just down the road from there.
98 GSX (built)
03 BBY EVO dd
GSX 463awhp 363awtq on DB!
Old 06-08-2012   #342
GsXtUrBo98
GsXtUrBo98's Avatar
Got the axle in and changed the oil. Also, I ordered my cdi ignition box from map and should be in on Monday
98 GSX (built)
03 BBY EVO dd
Old 06-15-2012   #343
GsXtUrBo98
GsXtUrBo98's Avatar
Went and picked up my dyna tec cdi today from map but did not install.. Went to the gas station to fill her up and she runs great with the fresh gas but the rear end still clunks even after replacing the 2 rear axles with hd ones..... I guess it could be the rear diff itself..
98 GSX (built)
03 BBY EVO dd
Old 06-15-2012   #344
Does it clunk when shifting? If so, it's probably the rear diff bushings. Evo's do the same crap. Doing new rear diff bushings and driveshaft bushings cures it most the time.
Old 06-15-2012   #345
GsXtUrBo98
GsXtUrBo98's Avatar
No, its only when I'm making a sharper turn.
98 GSX (built)
03 BBY EVO dd
Old 06-18-2012   #346
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
Does it clunk driving strait, turning, or both?
Amsoil Dealer
Old 06-19-2012   #347
GsXtUrBo98
GsXtUrBo98's Avatar
Turning
98 GSX (built)
03 BBY EVO dd
Old 06-19-2012   #348
Do you have a welded center diff?
Old 06-19-2012   #349
mike55112
mike55112's Avatar
Drives: 04 evo
He does
03 as evo-sold
04 bby ssl-sold
05 ww mr-sold
03 tb evo- current
Old 06-19-2012   #350
Are you sure that isn't the noise you are hearing?
Old 06-19-2012   #351
95talonracer
Finally Tuned...
Drives: Spyder GSX
That is def from having a welded center diff. Happens to all with a welded diff if you are turning in tighter areas.
Amsoil Dealer
Old 08-14-2012   #352
GsXtUrBo98
GsXtUrBo98's Avatar
So I installed a dynatek arc2 and am still having break up problems.. I was at 27psi and turned it down to 25psi and it wasn't as bad. But then I turned it down to 22psi and she goes pretty damn smooth through the gears.. I think I'm in need of a retune..
Note: I also fixed some boost leaks but there isn't any difference from before or after since they were before the maf
98 GSX (built)
03 BBY EVO dd
Old 08-14-2012   #353
blackawdtsi
Drives: 2G DSM
What are your plugs gapped at?
Old 08-14-2012   #354
GsXtUrBo98
GsXtUrBo98's Avatar
20
98 GSX (built)
03 BBY EVO dd
Old 08-14-2012   #355
what plugs?
Old 08-14-2012   #356
GsXtUrBo98
GsXtUrBo98's Avatar
Ngk bpr8es
98 GSX (built)
03 BBY EVO dd
Old 08-15-2012   #357
blackawdtsi
Drives: 2G DSM
If they're more than a couple months old, I'd try new plugs first.
Old 08-15-2012   #358
Why are you running those plugs may i ask?
Switch to BR7ES and see if that changes. If you are on E85 those may be too cold.
Old 08-15-2012   #359
GsXtUrBo98
GsXtUrBo98's Avatar
The plugs are brand new just installed. Brad ran them in his 2g so I through them in last year and hadno problems..
98 GSX (built)
03 BBY EVO dd
Old 08-15-2012   #360
hmm, i guess I'd try the BR7ES and see if they help any, cheap enough to try.
