Old 06-26-2013   #361
carltalon
carltalon's Avatar
Drives: 98 Eclipse GSX Auto
Re: 2G auto S/A daily
keeping these things cool with a FMIC is a pain. My car was dead set at sitting at 219 all the way home from BIR I had to go back to stock fans last year to keep mine cool. The cheap slims I had wern't cutting it. I drove right past your place last night while I was picking up some tires for my other project. I almost called you to see if you were ready to do some WOT tuning but it was getting pretty late.
11.35 @ 120mph
Old 06-26-2013   #362
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Sounds good just picked 2 up.
I feel better now that you said yours was at 219
I was driving home from Iowa from 1-5 am so I wasn't home
Think ill be ready for wot tuning come Friday
Wanna try to make rock falls Saturday.
Old 06-26-2013   #363
carltalon
carltalon's Avatar
I think I'm good on track outings till its a little cooler. I'm hoping to be wrenching on my old car Friday and Saturday but I could mabey help with some WOT tuning on Friday night
11.35 @ 120mph
Old 06-26-2013   #364
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
K ill keep ya posted.
Old 06-26-2013   #365
Two bottles should be plenty. I would start by pulling the thermostat out to make sure that isn't a problem. It sounds like you have a major issue if it is getting that hot. That was with 1 fan working, right? If you had no fans, then I wouldn't get too worried about it.
Old 06-27-2013   #366
The high this weekend is barely over 80*.
I know a guy selling a badass radiator and dual fan setup.
Let me know about sat. I can try to help you make it.
Old 06-27-2013   #367
If you go to the rock text me dude. I'd probably come watch if you went
Old 06-27-2013   #368
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
I have an aluminum radiator and nice slim fans. I don't think that's the issue.
That would also cut into my t3 budget.
Yeah ill have to see what's up as far as help I'm sitting at 811 for miles right now and still have to run to 694 and rice so ill change the oil and check the thermostat tonight.
Old 06-27-2013   #369
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Will do. Just gotta see if Tom, Carl or Aaron has time to help me street tune tomorrow night.
Old 06-27-2013   #370
I work until 1030pm tomorrow.
But I wouldn't worry about T3 if the car is running too hot, also not all AL radiators are created equal that goes for fans too.
I'm down to go to the track too. Want to see some deep 11s-10s with that thing.
Old 06-27-2013   #371
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
I bought a 180 stat so gonna throw that in while I drop the oil today. Should be at 900 miles when I get home today. And really has no major iissues/leaks since 100 miles.
Old 06-27-2013   #372
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
I have never had issues with mine running hot... ESPECIALLY with E85! Usually I have a hard time getting mine to warm up fully without beating on it in anything less than 80* weather.
I would definitely start with the thermostat. Something definitely doesnt seem right. Last year when we had a bunch of 100°+ days my car would barely make it to 200°. I have a 180° super stat in it and run 60/40 - coolant/water.
If you go Sat, shoot me a text and maybe I'll fly up on the bike if its nice.
Originally Posted by shoutbox
Old 06-27-2013   #373
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Sounds good. Ill let ya know if I'm gonna make it out there.
Old 06-27-2013   #374
I have a mitsu 168F stat. too if a reg. one doesn't cut it.
Old 06-27-2013   #375
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Ill let ya know. If not ill order a 160 from map.
Old 06-27-2013   #376
carltalon
carltalon's Avatar
From what I've read 2g run alot hotter the 1gs due to the coolant running the opposite way or the location of the temp sensor. I freaked out the first time mine went over 200 but after researching I found its not that abnormal. I also have the ac condenser in still and a restrictive fmic. Sounds like it's in the right range for a stock thermostat. Hopefully the cooler one works out.
11.35 @ 120mph
Old 06-27-2013   #377
I was constantly fighting to get my 1G to stay cool. A different (less dense) FMIC ended up helping a lot, but still was always a struggle. Lower temp thermostat, higher pressure rad cap, water wetter, fans always on, ducting, and the ETS FMIC (replacing a dense garrett core) I was finally able to get the car to stay more normal. Forget turning on the A/C though. That was probably one of my biggest complaints/annoyances with my 1G, just not overheating.
Old 06-27-2013   #378
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
So far it hasn't gone past 210 so I think it's good now. Time will only tell though.
Old 06-27-2013   #379
dsmreck
dsmreck's Avatar
Drives: 98 gsx
nice to see thats all it was.
Old 06-27-2013   #380
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
New thermo tested before I put it in and worked fine. Car got up over 225 and tripped the light.
All this was done around after 9 so air temps should of been fine.
I have no mixing of coolant and oil in either so not sure what to think yet.
What's the best way to get bubbles out? I'm not sure I got them all out but that's really the last thing I can think of.
Also for a sidenote. On my car it goes intercooler, fans pushing them radiator. Should I put the fans on the inside of the engine bay?
