Old 10-17-2006   #22
twack
It was a auto get over it
twack's Avatar
Re: Wierdiest thing ever! Help anyone?
so i went out there and now it wont start it all powers up but it wont turn over
Old 10-17-2006   #23
HiImBrian
HiImBrian's Avatar
Drives: the girls crazy
Maybe it was like a final goodbye. She just started once to say goodbye!
pics or gtfo
Old 10-17-2006   #24
Elementality158
Elementality158's Avatar
Send a message via AIM to Elementality158
I tried to start my car today after work.... Ended up getting a ride from someone home. just be happy. but really get the thing out of here. Or bring it over and have it help my car out.
Elementality158 is offline   Reply With Quote
Old 10-17-2006   #25
Thor06
11 Seconds to Freedom
Thor06's Avatar
Do you have a rodent problem? I think it possible that when it got cold one of those fuckers came in and is making a house in your car. Maybe nibbled on a few wires and got them to short causing it to start. I would look the wiring shit over good.
Old 10-17-2006   #26
HiImBrian
HiImBrian's Avatar
Man thats gotta be a smart rodent to be able to hotwire a car!
pics or gtfo
Old 10-17-2006   #27
twack
twack's Avatar
no rodents but now it wont start. i hear the fuel pump come on and there is absolutly no power going to the starter. what do you think i should do
Old 10-18-2006   #28
Sounds like something in the wiring near the switch or the ignition switch itself died. Only the ignition switch/wires to it, can send power to the correct spots to start it.
Old 10-18-2006   #29
Gravy
Who's this guy?
If it's a manual, be happy you didn't park it in gear. That would have made for a REALLY freaky event.
Your wire is probably messed up, doesn't even have to be from a mouse. Your car is a DSM you know.
Old 10-19-2006   #30
twack
twack's Avatar
Well i picked up a new starter and threw that in and now she starts!!! so hopefully the car will be good and not mess with me anymore
Old 10-19-2006   #31
Gravy
Who's this guy?
Sound like what was listed on tuners? Did you notice any lose wires or carbon scaring where it may have jumped?
Old 10-19-2006   #32
Check the Remote wire for the starter, its on top of the starter, just a 10-15 ga wire.
I was having a wierd thing like this where i accidentally shorted the remote wire and the car tried to start. scared the shit out of me because my hand was deep in the engine at the time. But that would explain why your car wont start now.
Other then that, that freakin nuts. I would call your local priest for an exorcism asap.
Old 11-14-2006   #33
Sparky2211
Sparky2211's Avatar
Drives: 2g DSM, 2008 Evo X
Hmm... no remote start and no turbo timer... There is really weird! Spirits?
1997 Eclipse GSX - Project car - 601hp/475tq
2008 Evo X GSR SSS - Daily Driver - 407hp/434tq
Sparky2211 is offline   Reply With Quote
Old 11-15-2006   #34
So if the key was not in the car how did you shut if off? Or did it die when you went into the garage? JET is correct the ignition switch would have needed to be on and power going to the MPI relay and the ECU/fuel pump other wise a shorted wire to activate the start would only turn the motor over, but it would not start. I would assume the garage was filled with exhaust fumes and the radiator and such was warm/hot from the car running for 15min?
another vote for spirit or somthing. I was at home watching tv and at 1am in the morning the light over me turns on for no reason, that was wierd.
Old 11-15-2006   #35
twack
twack's Avatar
Ya it was filled with fumes and the first time it happened like i said it died as i was opening the garage door the second time i pulled the neative wires
Old 11-16-2006   #36
x-pride
x-pride's Avatar
You have a wiring issue somewhere in the car. It is serious problem because if your car was in gear life would really suck.
Old 11-16-2006   #37
twack
twack's Avatar
its an auto and it was messed up wires in the sterring coloumn where im guessing the previous owner TRIED to put in remote start or an alarm
Old 11-16-2006   #38
x-pride
x-pride's Avatar
Check under your dash to make sure he did not leave any wire open or any wire tape together. All you need is to add to volts to your ignition or starter wire and the car will start. The auto start might still be in the car. So, it might be faulting out. Go under the dash and look for wires that is not factory. Follow the wires and it should lead you to the brain. Disconnect the brain. Once you disconnect the brain try to start the car. If it does not start you will need to put the brain and take it to someone who know alarms and have them solder back you starter and ignition wire.
Old 11-16-2006   #39
twack
twack's Avatar
Already solved, but i think he tried to wire an alarm to the starter cause the starter kept going in intervals while it was started so it was all messed up. now its fixed.....anyone want to buy a alarm/starter j/k
Old 12-10-2006   #40
Chris
Chris's Avatar
Send a message via Yahoo to Chris
Honestly that is the wierdest thing i have ever heard. Glad to see you got that fixed . Do some more praying next time .. LOL
Chris is offline   Reply With Quote
