Old 10-22-2006   #21
91nbtsi
Send a message via AIM to 91nbtsi Send a message via MSN to 91nbtsi
Re: 2-step
One of the wires from the switch goes to ground when the clutch is pressed. So, you just need to figure out which wire that is and then cut the OTHER wire and run that to an input on the AEM. Then for activation in the AEM just put whatever input you have to "ground=on" I believe. I don't remember which wire it is, but that is the general procedure you need to do. I used the clutch switch and loved it, works great!
10.806@133.15--1991 Talon
91nbtsi is offline   Reply With Quote
