Old 01-08-2007   #21
X|Crescens
Re: Fuel?!
I will rewire the fuel pump, that isn't a big issue. I would however love to dyno with exhaust on/off and turbo on/off to see results but like you said it isn't free. I'm going to get a dyno tune probably after everything is installed and/or after I install cams.
X|Crescens is offline   Reply With Quote
Old 01-08-2007   #22
Re: Fuel?!
Get a dyno-tune EVERY time you perform a major mod such as installing a new turbo, injectors, cams, etc unless you actually know what you are doing, even then a dyno-tune is a great idea.
Old 01-16-2007   #23
Elementality158
Elementality158's Avatar
Send a message via AIM to Elementality158
Re: Fuel?!
Rewiring fuel pump? What is ment by that? What purposes does it serve?
Elementality158 is offline   Reply With Quote
Old 01-16-2007   #24
Re: Fuel?!
Search the VFAQ. Basically its sending a constant ~14V to the fuel pump instead of the stock ~12.5V in order to get a higher flow rate and a more constant delivery.
Old 01-16-2007   #25
Elementality158
Re: Fuel?!
thanks. ill check that out
Old 01-16-2007   #26
Re: Fuel?!
Not that it matters now, but my walbro 255 is nearly silent in my quest, and it's mounted outside the tank and under the rear floor, which has no insulation over it. I can't hear it inside the car.
