Old 04-09-2007   #21
Pianoman
Re: F/S 2g with built 6 bolt/50 trim 6000/bo
Originally Posted by Tenacious2g View Post
To get it back to running condition just need to slap in some rings. It ran PERFECT before the ring went bad (-26psi on decell) and still reads that. I pulled the plugs and couldn't see any imperfections on the piston. Most 2g's with a 6 bolt have the random misfire but mine doesn't. It does start like a frickin pig but that is only when the block is cold. After the block is warm she runs fine.
You cant just slap in some rings and call it good. What caused the ring issue before will most likely cause it again.
Pianoman is offline   Reply With Quote
Old 04-16-2007   #22
Tenacious2g
True, but the problem should be fixed now. The old fpr was rising 2-1 instead of 1-1. I drove it like this for a week and tuned it again with a new fpr. What really gets me is the first fuel pressure reg I put in. It is a brand new Aeromotive, it was failing at first, it magically started working on the dyno and failed again about 25 miles after.
Tenacious2g is offline   Reply With Quote
