Old 10-05-2007   #21
Re: heat?
Yes it comes out of a pump, but calling e85 "pump" is a little deceiving I think, because typically people think of 92 or what not as "pump".
Old 10-08-2007   #22
badinblack
badinblack's Avatar
Re: heat?
It does come out of a pump. I'll count it!
Old 10-08-2007   #23
Re: heat?
It comes out a pump, costs less than race gas, is found at 300+ gas stations in MN including Holigays, and changes all the time. It must be pump gas.
Old 10-09-2007   #24
Re: heat?
Originally Posted by AwdGSX13 View Post
you could also heat wrap the mani and downpipe. It helps to reduce engine temps. I think you could even get heat wrap at checker or some place to that extent.
Mark (TKR) could chime in on this if he wants, but he just had a DNP mani crack because it was wrapped. I thought I remembered him saying something that DNP advises against wrapping them for that specific reason.
Old 10-09-2007   #25
Re: heat?
I put some thermo-tec heat shield shit on the underside of my hood tonight. It's not sticking too well to the un-smooth surfaces of the CF. However, could I get some short, small self-tapping screws, and screw into the ribbing part of the underside to help keep it stuck in it's place?
-A. Swift
Old 10-10-2007   #26
Re: heat?
The screws could work, but I'd be concerned that they would pull out of the CF quite esily.
Old 10-10-2007   #27
Re: heat?
I would look at some better adhesive. You don't want to crack the CF. Super 77 is great stuff, but I am not positive it would take the heat. Fleet Farm has a great selection of stuff like that. Silicone might be another option.
Old 10-10-2007   #28
Re: heat?
to stick it to the underside of the hood?
-A. Swift
Old 10-10-2007   #29
Re: heat?
Yes. Contact cement would be another option, if it will hold up to the heat.
