Old 11-22-2007   #21
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
Re: Project Turbo Snowmobile
Originally Posted by crazy_skier View Post
one thing that I remember from when I was looking into turboing my yamaha viper is that you still have to keep the bulge pipes. These are what pull the exhaust out of the engine and keep it running good. You could get away without them but your low end would be horrible. Again, I would look into adding some secondary fuel farther upstream to help compensate for the boost pushing the mixture strait out of the cylinders.
Ya I am making a manifold that bolts right up to the end of the pipe and a, also adding in an electronic fuel pump that will only kick on under 0 psi and above. I am still running the stock fuel pump as well with a one way check valve on it so fuel cant be pushed backwords through the stock fuel pump when the electric one kicks on.
Amsoil Dealer
Old 11-22-2007   #22
2.SlowES
2.SlowES's Avatar
http://forums.hybridz.org/showthread.php?t=115270
They seem to go pretty in-depth on this same topic, maybe it will help.
2.SlowES is offline   Reply With Quote
