Old 11-18-2007   #21
Re: big brakes~
Are the 2g brakes bigger then 1g's? if I upgraded the 1g calipers, do I need to swap the rotors too?
-A. Swift
Old 11-18-2007   #22
98gstaherns
I need boost in my life
98gstaherns's Avatar
Drives: '14 chevy 1500
Re: big brakes~
1g is 10.2 and a 2gfwd is the same and awd is 11.
Tyler Aherns
-USN-
Old 11-18-2007   #23
Re: big brakes~
2g AWD and NT 1g 3/S's are the bigger brakes, you need the brackets too.
Old 11-18-2007   #24
Re: big brakes~
but if I just found some 1g dual piston calipers, i'd be fine? If I converted everything from a 2g awd, like brackets, and calipers, I'd need aftermarket 2g rotors, and SS brake lines?
-A. Swift
Old 11-18-2007   #25
xveganxcowboyx
Wanker
xveganxcowboyx's Avatar
Drives: 95 M3
Re: big brakes~
I converted my 1G to 2g 2 pistons. I used the 2 piston calipers, caliper brackets and 2g rotors. The lines are not necessary. Your stock ones will work fine.
Old 11-18-2007   #26
Re: big brakes~
Aren't 1G AWD big-brakes (92.5-94) the same size as 2G AWD brakes?
Old 11-18-2007   #27
123abc
wants to be sideways...
123abc's Avatar
Drives: Loud cars
Re: big brakes~
That's what I was under the impression of...
Old 11-19-2007   #28
Re: big brakes~
Yes, the kracka is right. So, you want better braking but don't want bigger rotors?
Old 11-19-2007   #29
twack
It was a auto get over it
twack's Avatar
Re: big brakes~
Damnit im in the middle of doing this, i think i have all the right parts coming to me, but this thread has me lost now i guess ill just wait till i get all the parts in to see if it works
Old 11-19-2007   #30
Re: big brakes~
You just need the calipers, brackets and bigger rotors.
Old 11-19-2007   #31
Re: big brakes~
For the 2 piston calipers you need the bigger rotors as well.
But just for reference. I did a track day at Brainard with my 1 piston calipers, good Brembo cross drilled rotors front/rear, good fluid(Motul), and good pads(Hawk something crazy..), and stock lines. It was great at the track, it did fade a couple times, but very manageable.
However, I now have the 2 piston calipers(SS lines up front) and with some average pads, it already feels better(with Brembo slotted rotors and basic dot4 for now). I have to get some special fittings to get the rear SS lines to fit. I would highly recommend those to everyone.
