Old 02-28-2008   #21
Re: Clutch hydraulic system
Even DOT3 would work just fine. I believe the only difference in DOT3 and DOT4 is the boiling point.
Old 02-29-2008   #22
Andrew7dg
Built it from scratch!
Andrew7dg's Avatar
Drives: Currently Mitsu-less
Re: Clutch hydrolic system
Thank you Andrew for your suggestion, and yes, it is adjusted all the way out, anymore and the u-shaped nut would fall off the end.
Making sure once again because it sounded like you missed a step...
You can take the nut off of that rod and twist the rod. With your hand. The rod will back out of the master cylinder to give you more play. Just make sure that it doesn't fall out of the master cylinder. Once the rod has been twisted out a couple of turns, put the nut back on.
