Old 09-27-2008   #1
Febo
Manic Narcissistic
Febo's Avatar
Drives: IS300
A conversion, a rebuild, and a swap.
Well, lets go ahead and start this off with saying that this took me a lot longer than I wanted it too. Even with the limited prep work I was able to perform. With that said. Lets get going onto the work performed. The cars worked on were both 92 DSMs. One being my DD Eclipse GSX Manual, and the shell being a Eagle Talon TSi AWD Automatic. Which is where the conversion came in.
(All photos are thumbnailed for ease of viewing)
The Conversion:
I did all the pedal and master cylinder work before I started on the actual project. The only components swapped during my week of hell was the clutch line and slave cylinder. Now lets kick it with some photos and captions.
Here we are with the auto shift lever exposed. Im sure everyone has been to this point on their car at one point so no explination is needed.
The next two photo's show the immense cluster f*ck of wiring headache that came with this shell that I had to clean up. Keep in mind, all this wiring is purely for a turbo timer, EGT, and electronic boost guage
Now here we are with the whole shifter assembly removed. This involved pulling the shift cable, the brake to shifter cable that locks you out of being an idiot and going into reverse when your going forward, the cable that runs to the ignition, and some electrical crap which I just simply cut and threw away.
Now what came next doesn't have a lot of photo documentation but I'll describe the horror. First the steering column has to come out. that involves about 13 bolts, some sort of marking paint or ink, and about 5 electrical connections. Then the brake pedal came out which involved removing the brake booster from the firewall (later found out this can be done without opening a single line) and about another 9 bolts and nuts.
This whole process was then repeated on the donor car, with the addition of removing the master cylinder and the shifter cables. Later found out the pedal assembly was bad on the donor car, so this process was then performed yet again at the end of my project.
MASTER CYLINDER REMOVAL IS MURDER!!!!
Then using what ever you wish to use you have to cut out the blanks where the master cylinder and the shift cables will run. I used a dremel with a carbide bit. I highly recommend it.
After that was the whole installation process of running cables, installing the pedals, and putting the shifter in. No real tricks or issues with any of this. Oh yeah, be sure to get rid of that pesky TCM. Its worthless to you now. Also search the vfaq and remember to connect the two black wires on your inhibitor switch so that you can start it. Its located by the battery box and is a 12 pin plug.
Then as stated earlier, I removed the clutch line from my GSX and added it to the Talon during the actual project while I had the engine on a stand. It made life a lot easier. Its a pesky item to remove and involves pulling the cruise control from the firewall, disconnecting a brake line at the ABS control module, a couple of clips, and lots of careful fenagaling to get that sucker out without crimping it. Installation is the reverse of removal.
Now its time to put some pizza rolls in the oven. And begin working on chapter two, Engine Removal and Rebuild: With Extra Swapage!!!
