Old 10-09-2008   #21
Re: Insane tube evo
Fuel pump. Similar to this:
http://dvdtfab.com/?p=188
Yup a mechanical fuel pump like the big boys use
That billet front cover is.....a work of art.
Old 10-09-2008   #22
Re: Insane tube evo
Why is a machinined front cover even needed though? I can see a solution for the balance shaft hole,..... Oh. This is a dry sump setup, they got rid of the oil pump and all the balance shafts....
Old 10-09-2008   #23
Re: Insane tube evo
No, the oil pump seems to be there. It is at 4 o'clock. I would like to see the engine out of the car but fully assembled!
Old 10-09-2008   #24
Re: Insane tube evo
Albert (dv/dt) makes them for Magnus. I have a ton of respect for the guy. He's got a MechEng degree from the Univ of Chicago and his dad owns a machine shop, so he's got a ton of machining experience too.
Trivia question: What university did he start his ME degree at?
Old 10-09-2008   #25
Re: Insane tube evo
The U of Who Cares?
Old 10-09-2008   #26
Re: Insane tube evo
No, that's just the mount hole an empty pulley for the timing belt. It looks like most of the use of the billet front plate is for a real secure mount for the dry sump pump.
Old 10-09-2008   #27
Re: Insane tube evo
I'm going to bet some place in Iowa.
Old 10-09-2008   #28
Re: Insane tube evo
LMFAO. The evo is a tractor???
Old 10-09-2008   #29
Re: Insane tube evo
Huh, it just says it uses a modified Magnus oil pump, not dry sump. If you look in the picture of the engine installed in the car it also has the stock oil pump gear on it. Are they just using that for the timing belt?
Old 10-10-2008   #30
Re: Insane tube evo
Jet, what do you think that object is to the right of the front cover in the last pic.
I think it looks like a dry sump pump. Or maybe a vac pump?
Old 10-11-2008   #31
Re: Insane tube evo
That pump is not actually installed in the Evo. Look at the harmonic balancer, there isn't another belt running in front of it and there also isn't room for it, there is a piece of the frame there. I do agree that is a dry sump pump. Maybe that is for a different car?
Old 10-11-2008   #32
Re: Insane tube evo
Perhaps something like rwd application
Old 10-11-2008   #33
Re: Insane tube evo
The U of Who Cares?
Hah, dick, the great Iowa State University.
Old 10-11-2008   #34
98gstaherns
I need boost in my life
98gstaherns's Avatar
Drives: '14 chevy 1500
Re: Insane tube evo
I wonder what kind of gas mileage it gets? lol Sweet ride
Tyler Aherns
-USN-
Old 10-12-2008   #35
Re: Insane tube evo
Shep has/had the same damper pulley and what looked like the same 3 stage scavenge pump (dry I would assume), if that helps at all. Now I know what I need to look for used when my car runs again.
Old 10-12-2008   #36
Re: Insane tube evo
wtf, double post ftl.
