Old 02-03-2009   #21
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
Re: A real mans DSM :D, Introducing, the Starion
Looks like a good find.
Old 02-03-2009   #22
311evo
311evo's Avatar
WOW nice snag!! i like it!
Old 02-04-2009   #23
2bar1g
Member
Drives: .
Dude, that is an awesome find!
2bar1g is offline   Reply With Quote
Old 02-04-2009   #24
Very nice! I loved my starion, that was my first turbo Mitsu.
Old 02-04-2009   #25
mdost03
Sonic Champion!
Drives: VA STI
Nice lookin ride!
Old 02-04-2009   #26
Looks clean!
Man that interior is so 80s. lol
Old 02-04-2009   #27
mx3twinturbo
mx3twinturbo's Avatar
Drives: StarQuests>>>>>>
As far as vac lines, If you need some help, I'm game, I also want to see it,
Jesse-
1987 Conquest- 2.1 project started...
1986 Dodge D-50- S.C. truck 2.6 turbo swap started
1992 Mazda Mx-3- Rear mount twins in progress
1989 Suburban- Project for too Long!!!
"Just Remember, I HATE Drama"
mx3twinturbo is offline   Reply With Quote
Old 02-04-2009   #28
Nice! I've always liked these cars, and almost got one a couple years ago, but picked up my DSM instead.
Old 02-04-2009   #29
Shotgun!
Totenritt
Shotgun!'s Avatar
Don't change ECUs, the 86s had the best ones.
Old 02-04-2009   #30
Reid, did you mention something about how the '86 ECU doesn't need the MAS or something weird like that?
Old 02-04-2009   #31
Febo
Manic Narcissistic
Febo's Avatar
Drives: IS300
Tis true, they have a basic speed density setup for "limp home mode" which means unplug the mass and let er buck. Then tune accordingly.
Old 02-04-2009   #32
Shotgun!
Totenritt
Shotgun!'s Avatar
Word. Also they have a better injector setup. They fire their injectors; 1, 2, 1, 2, 1, 2. The 83-85 and 87-89 fire; 1, 1, 1, 1, 12, 12, 12 - like a carb. So the 86 ECU is half way to being MPI. You seem to have what's needed to go almost all the way.
Old 02-04-2009   #33
Why did they change back for 87-89?
Old 02-04-2009   #34
Well, that information is true, but somewhat misleading. The 86 ecu doesn't like it when you raise the boost past 13 or 14 psi, if you can even get there. Yes, you can take out the mass air sensor in SOME of the 86's. some cars don't care and might run better, others might run worse. There is a way to use a 1G mass air sensor with the 86 setup.
The 87-89 ecu, when used in conjunction with a 1G mass air sensor or a 1G maf translator allows for very high boost with no fuel cut (much higher than you could ever get with a 12a or 14g). The 86 does have a map sensor, but no AIT sensor. You can try unplugging the mass air sensor, but I'd wait till you have a wideband installed. Your stock boost gauge won't work either I bet.
Old 02-04-2009   #35
Febo
Manic Narcissistic
Febo's Avatar
Drives: IS300
Well, there already is no mas on my set up, its just a filter, and it did have a FCD installed but thats been taken out for some reason. The factory boost guage does work, but I dont trust it like a good DSM boy. I read about that 1g MAS set up and it sounds good, because if you can get a 1g mas to work, you should be able to get a 2g, or 3g mas to hook Id imagine. But I dont have the money yet to figure that out yet. Besides, Im still in the process of deciding if I wanna do a 2.4/3 swap into this beast and kick it that way. and just save the other two motors as back ups.
Old 02-04-2009   #36
I'd rock the g54 till it blows, then throw in a 4g setup and sell the other g54
Old 02-04-2009   #37
Febo
Manic Narcissistic
Febo's Avatar
Drives: IS300
Hmmmm, Im going to disagree with you there... Id rather have 3 engines, and blow up a 4g63/4 first before I blew up my stock motors.
Old 02-04-2009   #38
Didn't it come with a race built engine already? Why scrap that?
Old 02-04-2009   #39
Febo
Manic Narcissistic
Febo's Avatar
Drives: IS300
The rebuilt engine is already out of the car, and the g54 set up is still semi ghey because of the FI system. And 4g6x's have alot better mod support.
Old 02-04-2009   #40
MustGoFaster
MustGoFaster's Avatar
Drives: A big dirty V8
LS1! Fun cars, but they really need bigger turbo's to be a lot of fun.
