Old 02-26-2009   #21
iceminion
iceminion's Avatar
Re: What are DSM people running for tranny fluid these days?
Sand.
I mean Redline.
building a 3000GT AWD Turbo.
Old 02-26-2009   #22
s1ngletracker
s1ngletracker's Avatar
Drives: A BMW
you're clearly running the sand somewhere else.
Style's automotive engineer
Old 02-26-2009   #23
Neo
Old 02-26-2009   #24
hahahaha
Old 02-26-2009   #25
Amsoil is shit. I had a tranny with that had the redline cocktail in it for a while and it was starting to get a bit notchy, put in the amsoil and the car was barely driveable. I put the redline back in and it was back to just being slightly notchy. I also toss a few ounces of heavyshock into my redline cocktail for the tranny and also run that in the t-case and rear end. Now I only run Neo, it is spendy, but awesome.
Old 02-26-2009   #26
hippiekiller
hippiekiller's Avatar
bg synchroshift.
Old 02-26-2009   #27
311evo
311evo's Avatar
I had the amsoil also, everything would grind and just be a pain in the ass if you didn't rev match everything.
Got the redline cocktail, after a little while it was smooth as eggs!
Old 02-27-2009   #28
s1ngletracker
Drives: A BMW
I got the supplies for the redline cocktail.
Old 03-04-2010   #29
LaunchHard
LaunchHard's Avatar
So i have been running Penziol Syncromesh for a couple years now, but this passed year i had e tough time going into third under boost. Would it be worth trying the REDLINE MIX, or something else??
Also what proportions is the Redlione Mix and does anyone add the Shockproof? Does it make a difference?
Old 03-04-2010   #30
You only put shockproof in the rear end and transfer case. I believe when I put the redline coctail in my dsm I used 2 mt-90 and 1 mtl. It's been a while though, so I don't remember for sure
Old 03-04-2010   #31
CarPsyco84
CarPsyco84's Avatar
If you wanna wreck diffs, use GM Syncromesh, otherwise if you want actual gear oil redline from map seems to be the cheapest option.
-When in doubt, Moar RPM.
Old 03-04-2010   #32
awd-drifter
'2of9'
awd-drifter's Avatar
Drives: Racer Van V6
I'm using Royal Purple right now. Not bad at all. Gonna go royal purple this summer with the trans, transfer case and rear diff.
ლ(ಠ益ಠლ)
Old 03-04-2010   #33
I've done the heavyweight, and lightweight cocktail mix. Right now I think it's lightweight, MTL and MT-90. Either that or MTL and 2 lightweight. I forget.
Old 03-05-2010   #34
LaunchHard
LaunchHard's Avatar
can anyone verify that its 2 mt90 and 1 mtl?? Wheres the cheapest place to get this stuff?
Old 03-05-2010   #35
Get it at MAP. You can run those if you want, that's a good mix for smooth shifting. My mix is thicker, better for gears, and not soo much the syncros.
Old 03-05-2010   #36
I use redline. I guess Shep also uses it. So, I use it in his tranny. a mix of mt-90, MTL, and the pink heavy shockproof oil..used to use the lightweight stuff. Only reason I switched was cuz MAP was outta the blue shtuff last year.
-A. Swift
Do not put in to much Heavy or you won't beable to shift unless your transmissoin is very very warm. The stealth saw straight lightweight.
I've had horrible luck with Syncromesh and dsm transmissions. Better luck using the valvoline GL-4 stuff you could get at Napa when redline isn't available.
Old 03-05-2010   #37
I run straight mt90 in my eclipse. TRE has a good section (at least used to) on what fluid to use. Might help if you read that.
Last edited by Kracka; 03-05-2010 at 09:54 AM.. Reason: respect the forum sponsors
Old 03-05-2010   #38
Redline: 2 qts of MT-90 mixed with 1 qt MTL has proven to work very well and is what I've used for years.
MAP generally keeps plenty in-stock.
Old 03-05-2010   #39
I have used Syncromesh for years and everything has been fine. I will be trying a different fluid this year.
Old 03-05-2010   #40
I use straight hevey weight in the evo tranny now. it works alot better over the mix I took out.
I got it from craig. used the style discount and was cheaper than any one elce can sell it for around here
