Old 03-05-2009   #21
Re: Is this rim fixable?
No need for heat, it will be easy to get the bent part back to flat, the trick is getting the curve back in. It takes a big ass whack to do it. It is like a ball joint, you can smack it around all day and it won't move, but a few big smacks and it will move around.
Old 03-05-2009   #22
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
But it is aluminum and I don't want it to crack. I think some heat will help a little bit with that wont it?
-1990 Mitsubishi Cyborg 4WD-
Old 03-05-2009   #23
Precision Wheel in Hopkins.
http://www.precisionwheels.com/
Old 03-05-2009   #24
Heat it up and it will help to keep it from cracking. Even if it does, it can still be fixed. I had a similar bend to that in a more expensive rim along with a crack. I bent the lip back, brought it over to MAP and little Brown welded it up nice and neat for me. I had a friend come and match the paint and now you can barely tell. A replacement rim for mine was $550. Total to fix this with mount/dismount tire, welding and paint was $120, and about three hours of my hammer time.
Old 03-05-2009   #25
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Thanks Mark I'll see if I have the time to make the drive and maybe they can do something with it. If not then I'll just be heating it up and use a hammer and rubber sheet.
Old 03-06-2009   #26
I have bent a couple of wheels back and never had an issue with cracking without heat. Usually the crack will happen on the initial hit.
Old 03-06-2009   #27
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
True but it's not gonna hurt anything so I might as well heat it up.. I'll post pics after and see how it goes.
Old 03-06-2009   #28
xveganxcowboyx
Wanker
xveganxcowboyx's Avatar
Drives: 95 M3
Ok, thanks. You just said expert and I'm unsure of whether it should be welded or tossed. Just want a good opinion.
Old 03-07-2009   #29
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
About a half hour with a torch and a sludge hammer with some sheets of rubber I'm pretty sure I got it fixed. It won't be as straight as it was obviously but I got it as straight as I could.
Old 03-07-2009   #30
twack
It was a auto get over it
twack's Avatar
looks damn good to me
Old 03-08-2009   #31
they should be able to counter weight any minor imperfections you left. but looks really good.
Old 03-12-2009   #32
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Just got back from Discount tire. She rides as smooth as can be! Rim not fixable my ass.. I snapped a couple pics.
Not bad at all..
New tires
Old 03-12-2009   #33
BLaCk_1cE
BLaCk_1cE's Avatar
Drives: TB IX SE
Looks Good!
Old 03-12-2009   #34
xveganxcowboyx
Wanker
Drives: 95 M3
Wow, this gives me hope. I'm going to a tire shop some time this week to get a direct consultation on mine.
Old 04-03-2009   #35
lucasoil4u
Drives: talon tsi evo 3 25psi
it looks very fixable ive seen wheels that have been a lot worse that have been fixed. Good luck let us know if they get fixed.
Mitsubishi.... Special Cars for Special People.
lucasoil4u is offline   Reply With Quote
Old 04-03-2009   #36
^ WTF? Do you not even read the threads? He fixed it man. Stop bumping every old thread on the site.
Old 04-03-2009   #37
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Trying to get you're post count up or somthing? lol...
