Old 04-06-2009   #21
Re: Progress since last year
I made over 700awhp on twin walbros intank thru a 1/2" line.
Old 04-06-2009   #22
^oh well swifty is gonna make way more than that.
Old 04-06-2009   #23
Not only power, but fuel type has to also be factored in. 700hp on E85 requires quite a bit more fuel then 700hp on C16.
I also vote in tank dual 255's. It's just cheap and easy. That's what I'm running, still on stock wiring, still on stock lines with the exception of the line from the fuel filter to the fuel rail, and the fuel rail to the AFPR (both are short sections of -6 Pushlock). And it was apparently enough for me to make the power I made on E85 (well more like E70 probably).
Old 04-07-2009   #24
^how true.
I agree. I wish I would of done it too. But hopefully i run out of fuel at about 450ish and then I will stop with my car.
Old 04-07-2009   #25
Im not aaron..nor did I ever say I was, so shut it.
I also did the twin 310's because they are roughly 20 bucks cheaper per pump. Another thing to consider when you don't have the most money in the world to build a car.
-A. Swift
Old 04-07-2009   #26
santa
Boost Spike
santa's Avatar
Are you going to run a warped to fuck clutch pressure plate like you sold me without saying anything?
Wow Kerry. Seriously? If I knew it was warped when I had it I would have thrown it away. Like I said in my pm. It was a used pressure plate that worked perfectly in my car when I pulled it out. I have several people that will vouch for that. What more would you like? A one year warrenty on used parts? Sign me up for that one!!! What a mature way to attack someone who did nothing wrong. You took a chance on a used part dude. Hence why the pressure plate was only a $100!!! Plus I gave you several free parts from my parts car that I could have charged you for bit I didn't because, I thought you were a stand up nice guy. Hence why I made that thread saying you were a good guy. As in my pm I sent back to you I don't want any bad blood between us.
Old 04-07-2009   #27
True, but I was bringing up the example of twin intank walbro's should be plenty for most vehicles that still see street duty (or for gt40 pumps are also a great option). The external fuel pumps require voltage controllers so they don't burn out over time.
Old 04-07-2009   #28
Let this be the end of it. Take it to PMs if necessary. Posts concerning this from now on will be deleted.
Old 04-07-2009   #29
santa
Boost Spike
santa's Avatar
Thank you! Back to the fuel pumps. I still need to design a good flowing distribution block for twin pumps. Any ideas???
Old 04-07-2009   #30
I used a cheap little 3/8" barbed T-fitting from Ace Hardware, ha
Pretty sure Old Man Hill uses the same. Ideal flow wise, maybe not, but I'd say we've definately proven that it works.
This isn't mine, but is basically exactly what mine looks like.
http://dsmlink.com/forums/attachment...0&d=1205607153
Old 04-07-2009   #31
Dont use a t-fitting; use a y-block.
Here is a quote from kiggly on the topic:
"scaling for multiple pumps is extremely dependent on the fitting that merges the pump flows. A long time ago I was running a "T" fitting and two pumps in parallel barely flowed more than a single with this restriction."
Old 04-07-2009   #32
A "Y" fitting would probably have better flow than the "T" fitting, if you can find one. I believe Swifty used a NOS "Y" fitting outside the sending unit on his car.
^^ Same time post, doh!
Old 04-07-2009   #33
http://www.magnafuel.com/products/ac...ings/index.htm
Old 04-07-2009   #34
santa
Boost Spike
santa's Avatar
I'll throw a mid list up once I'm not on my iPhone. Or if I get bored a work.
Old 04-07-2009   #35
Interesting. I'd like to see more info on that if you have a good link.
I ask because I am running two 255's, in parrallel, with a "T" fitting, on E85, airflow right around 60lb/min, still on stock wiring, and haven't ran out of pump. I have a pretty solid 11.2 AFR until redline. If it really barely flowed more then a single pump, I would imagine I would have ran outta pump awhile ago considering I'm running E85, and also have not rewired them with thicker gauge wiring.
Old 04-07-2009   #36
I was doing more research on T vs Y and found evidence about T not working the best compared to Y.
I will post back if I can find, but if i remember right it was a 3am read so i probably didn't save it.
Old 04-07-2009   #37
santa
Boost Spike
santa's Avatar
I'm pretty sure I'll be running a Y fitting for the second pump if I go that route.
Old 04-07-2009   #38
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
If you do dual in tank pumps, are you going to put a spacer in between the 2 pumps? I talked to someone that said they had the 2 pumps right next to each other and they were actually fighting each other a bit so a 1/4" aluminum spacer was added between the 2 and it fixed the problem. Something to think about.
Amsoil Dealer
Old 04-07-2009   #39
santa
Boost Spike
santa's Avatar
Thanks for the heads up on that Kerry!!
Old 04-07-2009   #40
95talonracer
Finally Tuned...
Drives: Spyder GSX
Yep. The guy I talked to said that the 2 pumps right next to each other were actually fighting eachother and creating excess heat. In his case it actually burnt up one of the pumps and created signs of burning in the tank but no explosion thankfully. He said that a 1/4 spacer out of aluminum work and solved all problems. Let us know what you end up doing.
Amsoil Dealer
