Old 05-28-2009   #21
Re: the wifes (Ali's) new car 89 mirage turbo
worked on it some more today. I put on the 90 turbo tranny with the p.grip I put in it years ago for James. act 2100 p.p. new disk from Craig. act fly wheel. I moved the radiator mounts on the car so I can run a honda 1/2 size in the car. Put the engine in I got all the mounts for the mirage but the front roll stop mount so I used the one from the 90 eclipse and welded on some flat steel to make it work. I started to hook every thing up on the car. I also cut the engine mount off and the most of the power steering bracket to clean it up a little bit.
Old 05-28-2009   #22
Scheides' pistons?
Old 05-28-2009   #23
the pistons and rods out of nash's evo. just going to press of the pistons and give back the bad rods so chris can hang them up
Old 05-29-2009   #24
curt_gendron
curt_gendron's Avatar
Looks like a fun little project.
later,
Curt
Minnesota 3/S
Old 06-06-2009   #25
dad and I worked on it most of the day today. we got everything hooked up. picked up a starter from Craig. Came to find out the fly that I got with it was a act awd fly wheel so the tranny came back out. took us all of 20mins to pull it all back out and get the clutch and fly off. I
the oem n/t down pipe is 2.25. welded on a 2.5 pipe then steped to 3in to meet up with the 3in flex in the down pipe.
as it sits now all back apart no tranny in it
Old 06-06-2009   #26
keep on truckin! Can't wait for a ride in this thing.
Old 06-06-2009   #27
Awesome that it all works now!
Old 06-12-2009   #28
The car is now on the road for the first time in years.
Picked up a 90 oil cooler set up from greasemonkey thurs night. Worked on it till 1130 at night got it running this time with out any oil or coolant leaks. Also got the oil and volt gauges in still have to get a boost gauge to match. They are classic chrome autometer gauges I had laying around. Also picke up ass-hanson's jenson flip out dvd deck for the car and got that in and working.
Also hit up upullit on thurs after noon looking for a housing nothing there but picked up a 5g miage arm rest for the car it fits nice on the 3g center concel.
Only one problem with it right now is the the front pass brake is still draging. Going to look at it in the morring, but I do have a 5lug swap coming for the car,gsx 2 piston front brakes and a set of 3g eclipse (2g gsx style) rims for it now
Old 06-13-2009   #29
Constant_Project21
Constant_Project21's Avatar
Drives: E36
Awesome!! Need to see some pics once it starts coming together.
Old 06-13-2009   #30
got the pics loaded some from today and a few from last week
95 mirage shifter box and cables with 2in cut off the bottom of the shifter and welded back on
the classic chrome autometer gauges and the jenson dvd deck
black 5g mirage arm rest
Old 06-13-2009   #31
the batterys new home. still have to make an alum cover for the top and find the splash shields for the car
as it sits now
and a few others
not bad for a 89
Old 06-13-2009   #32
Constant_Project21
Drives: E36
I'm hella jealous, thing looks sweet. Mark think you could make me a aluminum cover for a maft? Don't have a cover on mine (sorry for being off topic)
Old 06-13-2009   #33
thanks
and I can when I find some alum sheet metal I can cut one out for you I will just have to get a little extra
Old 06-13-2009   #34
Constant_Project21
Drives: E36
Cool thanks, you have my number. If not I have yours.
Old 06-13-2009   #35
Good job dude!
Old 06-13-2009   #36
wootski!
Old 06-13-2009   #37
It drives really well also. This is the 2nd day it has been driven to work. The pass front calaper is bad I greesed it all up and it still is hanging up. So I will have to paint the 17's and swap it to 5lug soon as I get tires,rotors and pads for the front 2 piston brakes
Old 06-13-2009   #38
Looks nice.
Old 06-22-2009   #39
got some parts for it at back to the 50's this weekend
Found the best deal ever for horns for the car got a set for the evo,talon,and hatch. They are hella super tone horns the 118db ones that sell for 55.00 a set. I got them all new for 6.00 a set the guy had now clue what they were.
Polished s.s. coolant over flow tank for 35.00. Got it for the hatch back to get rid of the crappy oem plastic one. Kevin also picked the same one up.
Ali found a really cool hot rod style shift knob for the hatch new with the adaptor so it would screw right on for 26.00. it is made by gennie shifter
Old 06-22-2009   #40
LOL I LOVE the floormats!
