Old 06-23-2009   #21
v8klla
v8klla's Avatar
Re: Another reason I love my wife
I keep trying to get you guys to deal with the dedicated sales people over here, I'm a little rusty lol. In this case, however, it wasn't my fault for once. Apparently our vendor got it into their head that 2g and Evo gaskets are the same, which may appear to be the case until you realize that the Evo injectors are on the intake manifold! Sometimes I just can't believe the service in this industry...
Chris Carey, President
Modern Automotive Performance
P: 763-545-3800
E: chris@maperformance.com
Old 06-23-2009   #22
We just love you too much
Old 06-23-2009   #23
v8klla
v8klla's Avatar
Haha I hope you will love me for my imperfections as well
P: 763-545-3800
Old 06-23-2009   #24
No one is perfect.
Old 06-23-2009   #25
cmspaz
Walls need hugs too
cmspaz's Avatar
This.
And you know I'm cool about the flywheel, Chris. It's not like I've never made mistakes at my job, prepaying people at the wrong pumps or anything. We all do it, you're a great guy, and honestly, where would we be without you?
Originally Posted by Trogdor
Old 06-23-2009   #26
v8klla
v8klla's Avatar
Your cars would likely be running (albeit closer to stock form) and you would have more money in your pockets lol Thanks for the kind words guys!
P: 763-545-3800
Old 06-23-2009   #27
so it's your fault!
Old 06-23-2009   #28
cmspaz
Walls need hugs too
cmspaz's Avatar
Pssh, running cars and bank accounts with more than $100 in them are overrated.
Old 06-23-2009   #29
I thought the spacers were junk because they tend to melt and cause more issues then they make power? I know my spacer melted on my 2g causing a nice size leak and horrible tuning issues? Mine was from Magnus.
Old 06-23-2009   #30
After discovering the issue with the distributor Chris dug through some boxes and discovered the correct spacer!
I got home, scarfed some nummy greek food and got to it. bolted up intake manifold, threw the head on (THANKS AGAIN HUGHES!), and ran into a quick roadblock.
Last night I had the new L19's installed:
I ended up having to pull one of them back out once the head was on b/c the washers are so big it got bound up on the spring.
Once that was sorted, torqued the L19's to 91 ft-lbs, hooked up the cam gears, and put the valve cover on. Hughes had to take off just as Jim showed up to offer me moral support. I was gonna be done at this point but Anna was doing other stuff so I just kept my head down and buttoned everything back up! Filled the coolant and ran some o'reily's 10w30 oil through it for a few minutes, drained it, changed oil filter, filled with Mobil1 10w30 and started it again to make sure all was well. While the oil was draining I did a quick boost leak test and discovered that I might have ripped one of the injector seals when it popped in (felt a tish of a pop as it seated ). So, I'll check that out tomorrow and finish putting the heat shields and whatnot on.
Thanks again for all those who helped me, even those who didn't help this time around but helped me last time. Definitely not afraid to do a HG again, just hopefully its not on this car!
Old 06-23-2009   #31
That seemed to be the case before, but it seems as though those issues are a thing of the past. I have no EGR gasses going into my IM at all anymore, so the only heat will be from direct contact with the head and the bolts that hold it on.
Old 06-23-2009   #32
you coulda asked for help ya know..Also, don't you need an alignment?
Old 06-23-2009   #33
I got al the help I needed thanks swifty! I'll keep ya in mind for the set of bilsteins I have sitting on my workbench Yes, I will prolly need an alignment after those go in
Old 06-23-2009   #34
sweet. I already got david on a shopping list for his evo..so far, I've got a FMIC from ETS going on soon. Then, some coilovers, hopefully some black enkei RPF-1's in a 18x 9.5 variant or so, cams, springs/retainers, etc.
Your evo makes me jealous..just how responsive it is, and yet still pulls..seat of the pants, it feels as fast as my car. I want your car.
Old 06-24-2009   #35
DoughtCom
It's deluxe son... deluxe
DoughtCom's Avatar
Drives: Your mom
Man Scheides I'm so excited to have mine up soon! Glad MAP got everything sorted for your barrier gasket and that everything went back together well!
Hopefully mine works just as well
2010 Evo X GSR
1997 Subaru GC8 STi
Old 06-24-2009   #36
Buttoned up everything but the undertray and the strut-tower bar after work and made it out to Wagner's with everyone tonight. Felt so good to drive the car again! It's a ton of fun, but needs some tuning. Time for logging and a visit to DB.
Old 06-25-2009   #37
Working cars are fun
Old 06-25-2009   #38
^^ Working cars are definately more fun than working ON cars!! At least when you have to work on them when your not putting on go-fast parts
Old 06-25-2009   #39
311evo
311evo's Avatar
Nice Scheides! Hopefully this headgasket/studs will be a little nicer to you then the old one(s).
Old 06-25-2009   #40
I see 399.9awhp in your future.
