Old 08-25-2009   #21
Re: 91 Galant VR4
I think the AEM has 2 out puts for tranny control, either on/off so you get the 4 options that the tranny needs to run. I did get a little done on the exhaust manifold.
This is using the same fixture as before, but a little different runner lay out.
Old 08-25-2009   #22
Re: 91 Galant VR4
Madness. Can't wait to see it finished.
Old 08-25-2009   #23
Re: 91 Galant VR4
very nice.
Old 08-31-2009   #24
Re: 91 Galant VR4
Now I just need a waste gate and mount it to the manifold, a little final fit and finish, then finish weld. The runners are equal length for the #'s 1/4 and #'s 2/3 and will be divided all the way up to the waste gate valve seat. The turbo should be in the same spot as before, now I will just need to fab up the sheet metal end tank for the water to air and make a new down pipe.
Old 08-31-2009   #25
4seasons69
4seasons69's Avatar
Re: 91 Galant VR4
thats crazy! it looks really good. I wish I could fab stuff like that
Old 08-31-2009   #26
notsostockgalant
3g camaro owner
Drives: 88' camaro 400hp 327 sbc
Re: 91 Galant VR4
lookin good man built not bought, saves money lol and its done the way you want it too.
notsostockgalant is offline   Reply With Quote
Old 09-01-2009   #27
Nartanian
I will eat you aliiiive!!
Nartanian's Avatar
Drives: 1992 Galant VR-4
Re: 91 Galant VR4
Nice job man. Makes me wish I could do that too.
Just some corn and a MBC. Try it. You'll be amazed.
Nartanian is offline   Reply With Quote
Old 09-01-2009   #28
Re: 91 Galant VR4
Thanks, I will have the intake manifold done tomorrow night, then off to the flow bench to make sure it does what its supposed to.
Old 09-01-2009   #29
Re: 91 Galant VR4
Good, hopefully that configuration will bring the spool down a bit. Still plan on spinning this one to 9500?
Old 09-01-2009   #30
MustGoFaster
MustGoFaster's Avatar
Drives: A big dirty V8
Re: 91 Galant VR4
The return of the White Nissan!
Old 09-01-2009   #31
Re: 91 Galant VR4
looking good. It looks like the v2 will bolt on a lot easyer
Old 09-01-2009   #32
Re: 91 Galant VR4
Looking good! I edited your last post, just wrap your image links in img tags and they'll just show up, no clicking required
Glad this beast is finally getting some attention.
For those that don't know, this car made 600+whp at a dyno day a few years back:
http://www.youtube.com/watch?v=Rl9glSjfd50&hd=1
If you go manual, what clutch will you go with? Seemed that was an issue last time.
Old 09-01-2009   #33
Forced Fed
Drives: FS-T
Re: 91 Galant VR4
Super impressed with your fabrication work sir! PM sent, think I found out who I want to make my exhaust manifold for my sled.
Old 09-01-2009   #34
Re: 91 Galant VR4
9500-10,000 rpm, I think with the head porting re-work and more shims under the springs the power should hold a little better then before. I knew the clutch would be an issue from day 1, if I go MT I will be doing a twin disk.
http://www.jackstransmissions.com/pr...dbc8ebbf471212
or
http://www.maperformance.com/map-6-b...sc-clutch.html
As for spool up, between the clutch, leaky bov, and at some point I lost a exhaust rocker and bent the crap out of that valve, it should be a lot better. I also might have to upgrade to a ball bearing version of the GT4202, the standard bearing version will not last forever at high boost. And thanks for looking.
Old 09-01-2009   #35
Re: 91 Galant VR4
When do you plan on having this thing done?
Old 09-01-2009   #36
Re: 91 Galant VR4
Spring/summer of 2010, I hope.
Old 09-02-2009   #37
Re: 91 Galant VR4
Nice I'll be back around then. Hopefully it's making some sick power
Old 09-02-2009   #38
twack
It was a auto get over it
twack's Avatar
Re: 91 Galant VR4
i will probably be selling my shift box soon if your looking for auto tranny control or going with a paddle setup
Old 09-02-2009   #39
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Re: 91 Galant VR4
AEM > Shift box...
Looking good John! Glad to see you have the car and big plans again.
Originally Posted by shoutbox
Old 09-03-2009   #40
Re: 91 Galant VR4
Thanks. It turns out we need a pilot that is small enough to fit into the valve guide to do the valve job. Also I need to make an adapter plate to bolt my engine onto the engine dyno. The rear crash bar was removed, and the AEM/MSD mount was redone for a little less shin jabbing for the co-pilot.
