09-24-2009
#1
DSM's Dead
Drives: '91 Dakokta
Re: 1990 Eagle Talon TSi AWD
Originally Posted by TkrPerformance
sorry
do you know some one that works for the Plymouth PD. just seeing since the wife does she might know them
Nope, don't know a single officer anywhere.
Originally Posted by niterydr
That is what I was thinking... usually officers don't "pose" for pictures.
lol
Well, it just so happens that I pulled up next to him sleeping in his cruiser so he kind of "owed" the picture to me. He was really cool about it though. Once the three pictures were done I shook his hand and he went off to do whatever cops do.
'92 MX-3 KLZE Swap, I/H/E, battery relocate.
01-30-2010
#2
DSM's Dead
Drives: '91 Dakokta
A little update on what the hell's going on with the Talon.
Running really rough a few days ago while my roommate was borrowing it to get to and from work and school. Idle fine, but then bog down to roughly 300 RPM, then shoot back up to normal. The intake gasket had a/many holes/was completely destroyed. Replaced that a few days ago.
Two days later my back left wheel fell off on Highway 10 while on my way to work. No visible damage, nothing seems tweaked.
Still idling rough, ran a code 44 Ignition coil (cylinders #1 & #4) fault. That's pretty obvious after replacing the plugs since it needed to be done anyway. No, no Iridiums just yet, just cheapo NGKs. Going to test the coil soon and replace the spark plug wires as well, adjust the BISS, check TPS, adjust throttle cable, check any other related ignition sensors.
Still have to buy manifold studs to get the 2G turbo mani on and ready, then replace some more vacuum lines just for safety and then on to some tuning...finally.
02-01-2010
#3
Drives: E36
HOW?! hahaha
02-01-2010
#4
Just stick to the NGK BPR7ES.
Originally Posted by scheides
10-08-2009
#5
DSM's Dead
Drives: '91 Dakokta
Brought my car into the shop at Hennepin Tech to check on the alignment and wow it's horrible.
FL and FR Caster and Camber
RL and RR Camber and Toe
DSM lists front caster and camber as to be non-adjustable so it'll lead to drilling some holes or getting camber plates.
I'd've adjusted the rear camber and toe, however I didn't have time to heat up the bolts and spray PB Blaster on them to get any adjustments down.
The steering rack is also out of whack, time for a new one of those.
FR wheel bearing seems to be going out, so there's a change.
Also noticed that the rear brakes need to be done and should have been done about 5,000 miles ago. Parking brake also needs to be adjusted. Huh boy. Time for some work ahead of me to getting it not looking like a drift set up. Damn camber and tire wear.
Wideband should be ordered pretty soon here at the next pay check so I stop running so damn rich.
11-03-2009
#6
DSM's Dead
Drives: '91 Dakokta
Picked up a wideband today for $160. Yep, used. About 2000 miles on the gauge itself and 200 on the O2 sensor.
Since this is my introduction to tuning, is it necessary to hook up the blue wire (serial) coming out of gauge to the DSMLink serial cord, or can I just let it alone and Link'll do the rest?
11-03-2009
#7
CHeck th4 link wiki for info on hooking up inputs to the ECU.
There are a few choices, i used the baro input.
I would say look into 264/272 combo I have it and I love it, esp since u dont seem to care for a lot of power and want more a street machine.
11-03-2009
#8
Got Boost o_O'' m
Oh heck yeah! SAAWEETT RIDE! Man I wish I could of gotten that two tone color, im not digging that purplish maroon lookn with the silver buttom. Hehe If ya wanna get some cash for your side mount if you still have it HIT ME UP! ^_^
11-03-2009
#9
DSM's Dead
Drives: '91 Dakokta
Yeah, definitely looking for a street machine. Nothing incredible and out there. I think the tops that I'd be going for would be around 400 BHP, maybe a little more to give Vettes a run for their money.
Cams will still be a decision later on though. I was thinking the 264/272s, but brand I don't know which I'd be going with. Definitely want new if I'm doing it.
Yeah, still got the side mount; still attached to the stock piping...Aw, fail.
VR Speed FMIC would be awesome of course, cheap and from what I hear they're decent.
11-04-2009
#10
DSM's Dead
Drives: '91 Dakokta
Wideband is in! Time for a quick tune, set up the SAFC as well just for fun, add in the power inverter (super mega ultra bad battery in the POS Dell), and get her goin'. Also have to wire in the blue wire to the serial port and for that I gotta find the Chilton's.
Any suggestions?
11-04-2009
#11
No one around here talks in BHP, its about WHP. lol.
On flywheels, I've had both popular ones. Fidanza and ACT. I like the Fidanza's replaceable friction surface. I think the ACT is more street appropriate.
I'm making about 450awhp on DB's dyno on a stock bottom end and headgasket 4G63. And it's conservative, reliable HP (at least in my mind). Brad (Cel1ca) is making amazing power on his stock 4G63, but he even knows sooner or later it will go.
#12
DSM's Dead
Drives: '91 Dakokta
450 on a stock bottom end? Jesus. Looks like I just might be golden.
I guess WHP it is then!
Found out a problem though I'm not sure where it's coming from. Eating up oil pretty good. I have a feeling it's coming from the seals on the turbo, but I haven't looked into it much.
And I've learned that I've got to check for some vacuum leaks given the idle surge.
Also have to grab a new turbo manifold since there's a crack right down the top middle. Anyone have any suggestions that are in a good price range ($300-$450)? Word on the Treadstone Performance manifold?
11-06-2009
#13
Drives: 95 TSi AWD POS
A new evo3 mani would be a major improvement. Otherwise the forced performance one is sweet for the money too. Both would be at the lower end of that price range (means more money for other stuff). Tubular is nice for big power but cast is for sure the best bet for reliability.
How much oil are u using and any noticable smoke?
A boost leak test and a squirt bottle with some dishsoap water will find that leak in a snap (plus help clean up any greasy crap).
BTW pretty sweet ride. I gotta say Im a little jealous for how clean it is. Wish my 2g had the lack of rust your 1g does.
it's alive!!!
11-08-2009
#14
DSM's Dead
Drives: '91 Dakokta
lol Let's just say I'm decent with a camera. Notice the pictures don't show the passenger side, zip-tied bumper cover, close shot of the rear hatch, roof, interior, wheels, etc. etc.
11-07-2009
#15
I would in an instant reccommend the FP Race cast manifold. Stock fitment, great flow, and is very reliable. Good price also.
Look online on how to make a boost leak tester, very easy, and one trip to a hardware store.
#16
x2! i love my fp mani!
11-08-2009
#17
DSM's Dead
Drives: '91 Dakokta
FP Manifold it is! The only thing that I was worried about it was the price; seeing as it's so cheap, then again, it's cast and not really that expensive to produce, fits in the stock location without any terrible modification whatsoever (extend oil feed lines, etc. if applicable). Any numbers on either manifold, Evo 3 and FP?
Already got a boost leak tester, came with the vehicle. I will be doing the dish soap/carb cleaner leak tester pretty soon here, but first I've got to fix the new starting issue (Doesn't Start Much anyone?). Going along the lines of either the starter relay (since it is missing its casing and wrapped in duct tape: FAIL! or the ignition relay; aftermarket alarm system appears to have been installed before I owned the car which could account for a lot of voltage drop across the wires or a huge short to ground with a lot of resistance). Haven't gotten a chance to test it outright as of yet given work today, but tomorrow after work it'll get done and fixed, provided I have the necessary wire.
For how much that it burns, at a rough estimate, I'd say around 2 quarts in three weeks. Waaay too much. Had it been a 1/4 quart in two weeks I could stand, but at the much burning, good lord.
12-19-2009
#18
Drives: 2g
bought this car from mitch??
01-04-2010
#19
DSM's Dead
Drives: '91 Dakokta
Yes? I dunno. He goes to HTC. *Shrugs.*
Alright, gotta question. I want to swap in the 450s since the 550s that are in there now, in an untuned engine (wish I could afford it!), suck down waaay too much gas.
So, here we go:
16G
2G MAF
K&N
DeJon Tool UICP
Walbro/Equivalent 255 LPH
Only run 91 octane
I can't tune the engine on my own given it's winter and would be a bitch with the roads as they are, the cold, a vacuum leak, and a cracked manifold. I'd have time to swap the injectors, but don't have the time, nor the garage space right now, and even less money to get everything else up to par. So I'm looking for a decent quick fix that will allow me to save money in the future because of the damned gas mileage.
Anyways, question is, would I run a bit too lean with the 450s and the 16G? I've heard both ways, with different set ups and the same set up, so that's why I'm rather concerned.
Got Link and A'Pexi wideband to monitor just in case it does start pinging or going lean.
01-05-2010
#20
3g camaro owner
Drives: 88' camaro 400hp 327 sbc
550s with a 2g Maf shouldn't require all that much adjustment
