Old 11-20-2009   #1
GnArKiLl
GnArKiLl's Avatar
part out...OFFICIALY UNDERWAY!
i lost my job so i have to get rid of the car, but only if i have enough interest....mainly in the shell
the shell would be a clean black 93 eagle talon awd. 13x,xxx miles, was an auto but did a 5spd swap, wire tuck, 255hp fuel pump, 4 bolt rear.. will come with black racing seats. stock suspension, stock wheels.. i would need $1000 for it clear title in hand.. NO heat or a/c
pte 50trim rebuilt 500 miles ago comes with feed and return lines-$500
bc280 cams- 1000 miles on them- $325
skunk2 adj cam gears - never ran- $125
head with manley spring 1500 miles-$200
or get the head cams and gears for $600
6 bolt block with .20 over 2g pistons 1g rods 1500 miles comes as complete short block- $500
or a complete motor for $1000
transmission grinds at high rpm in 2nd and 3rd other than that shift fine-$200
act 2600 6puck unsprung-500 miles all easy miles- $300
fidanza flywheel-500 miles - $125
ets fmic with sls piping set up for gm maf and tial bov-$300
fic 650 injectors-$150
buschur/sx afpr with gauge and rail. $100
tial silver bov- $150
tein s tech springs on monroe struts-$300
NOS nitrous system, 10lb bottle comes with everthing you need but one line $200
coil on plug-$150
inovate wideband o2 blue gauge-500miles- $175
apexi pen style turbo timer with 1g harnes-$75
3" turbo back exhaust with exhaust depot down pipe - home made not the best, hangs kinda low-$100
sparco 4pt belts-$75
black poly mount already pressed in- $100
autometer boost and oil psi gauge in a pillar pod- $50
safcII black-$200
eprom ecu-$175
2- 12" slim fans $35 each
4" intake pipe with 3" reducer and K&N filter- $100
hallman rx mbc-brand new-$75
3" gm maf with maft-$150
4- goodyear eagle gt hr's 225/45/17 brand new never seen the road.. retail is $150 each... $300
2- brand new 95 amp alternators still in the box retail is $110 each plus core... $75 each
prices are firm and buyer pays shipping
again i will only part this out if i have enough interest... pics of some of the parts can be seen here.. http://www.mitsustyle.com/forums/showthread.php?t=23689
