Old 02-19-2010   #21
v8klla
v8klla's Avatar
Re: T-revzr's Evo
I heard only people that want high numbers and consistent comparable results that can't be "fudged" by the operator use a Dynojet
Fixed Sorry for the thread hijack!
Chris Carey, President
Modern Automotive Performance
P: 763-545-3800
E: chris@maperformance.com
Old 02-19-2010   #22
Re: T-revzr's Evo
But how much bigger is the FP Black compared to the FP Red? Do people really need the double pumper with the black?
Hmmm, not exactly what I wrote . But I'll leave it alone since this isn't my thread.
Old 02-19-2010   #23
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Re: T-revzr's Evo
I am using a double pumper with the red. So yea, you probably need one on the black. E85 is demanding.
Old 02-19-2010   #24
t-revzr
FLOSSEN
t-revzr's Avatar
Drives: 2011 corolla turbo S
Re: T-revzr's Evo
Well im on E85. I have heard the walbro 255 doesn't really work past 430 whp on a mustang dyno. So if I wanna push my car farther I was told to get a double pumper. Because I guess I would be fine with pte 1000's and a double pumper. Or maybe I'll just get FIC 1250's and run one pump. But if that dont work I could of saved money and not bought the injectors and just bought the double pumper.
Old 02-19-2010   #25
t-revzr
FLOSSEN
t-revzr's Avatar
Re: T-revzr's Evo
Ya Im kinda stuck dont know what to do!
Old 02-19-2010   #26
Murlo26
Murlo26's Avatar
Re: T-revzr's Evo
I got a blaqops one, they are real nice, pretty much what all the Evo X guys use. They make them for the 8/9's too.
I would personally get the double pumper and never look back.
At a minimum, with that size turbo you have, you should re-wire your 255 in tank so you can get more voltage out on it. Or as Shane had suggested for me at one point, you could do a KB boost a pump.
I still think a double would be clean and easy, but who knows.
Old 02-19-2010   #27
t-revzr
FLOSSEN
t-revzr's Avatar
Re: T-revzr's Evo
KB boost a pump never heard of it?
Old 02-19-2010   #28
Murlo26
Murlo26's Avatar
Re: T-revzr's Evo
http://www.kennebell.net/accessories...boostapump.htm
It's actually not a bad idea.
Old 02-19-2010   #29
t-revzr
FLOSSEN
t-revzr's Avatar
Re: T-revzr's Evo
Thanks for the info!
Old 02-19-2010   #30
Murlo26
Murlo26's Avatar
Re: T-revzr's Evo
No problem, ask Shane about it if you have more questions. I know he is familiar with them.
Old 02-19-2010   #31
Re: T-revzr's Evo
The boost a pump is a pretty easy way to go really. I make a little more than 500 on just boost at DB on e85, single 255hp, 1600s, stock fuel filter and lines, and a great tune. This is on a dsm, but I would imagine it would transfer over to an Evo the same way. I learned the idea from Shane and I know they (DB) has sold and installed a lot of them. Might be a simple/cheaper route.
I wanna see what this thing can do once its all finished up!
Old 02-19-2010   #32
Re: T-revzr's Evo
FP Black has a 82mm compressor wheel and the Red is a 76mm. Actually, the black has the same compressor as your DSM82 turbo (but in reverse rotation).
If you max out your pump with thse 1250s, this is the way to go IMHO.
Old 02-19-2010   #33
Murlo26
Murlo26's Avatar
Re: T-revzr's Evo
I think the boost a pump is cool and looks clean. However, the nice thing about the double pumper is you future safe yourself. I think the FPblack will be able to max out the Boost a pump...but I could be wrong.
Old 02-19-2010   #34
t-revzr
FLOSSEN
t-revzr's Avatar
Re: T-revzr's Evo
Just got off the phone with Shane. Were just gonna leave it how it is for now. When tuned will go from there and figure out what I should do next.
Old 02-19-2010   #35
Murlo26
Murlo26's Avatar
Re: T-revzr's Evo
That works too. Can't wait for numbers, should be sweet.
Old 02-19-2010   #36
mlomker
*Resting In Peace*
mlomker's Avatar
Re: T-revzr's Evo
Interesting product but I haven't read about any Evo builds that use them.
Consistent or not it does read higher than the other AWD dynos in town. I'm planning to run my car on all of them when my power mods are done...just for giggles.
Old 02-19-2010   #37
Re: T-revzr's Evo
Consistent and Comparable to what? Another Dynojet?
Dyno Dynamics are still better from a tuning standpoint, and any dyno can put out huge numers, all you have to do is change the correction
I hope you're not implying that Shane "fudges" the numbers...
Old 02-19-2010   #38
Re: T-revzr's Evo
BAP's have been in use forever and ever, Mellon used one on his evo8 for a LONG time:
http://forums.evolutionm.net/service...-reviewed.html
Old 02-19-2010   #39
Re: T-revzr's Evo
BAPs might even be older than evo's!!
DD load bearing dyno = awesome for SD style tuning.
Old 02-19-2010   #40
Re: T-revzr's Evo
BAPs are old. We have to use them on a lot of returnless style fuel systems with a stock fuel pump also, because Walbros often burn up when run on a returnless/deadhead fuel system. Me and Brad use them on our DSMs, Nate uses one on his 700whp Civic and Kiggly uses them or something like them on his 8 second FWD DSM.
