Old 02-17-2010   #21
Re: T-case bracing?
Aaron, just dishing it back .
I'd hafta dig up examples, but I know brent bennyhoff, jake montgomery, and others whom I don't know by name have grenaded their t-cases (1 including that green 1g on talk, if I remember correctly..big ted is his name?) My t-case and tranny are from a 91 galant, and for that reason, I dunno why, but the t-case is aluminum. I have thought about swapping the internals over to a cast case, but I found this pic earlier today, and got wheels in my head turning, and we all know what happens when wheels in my head turn (besides a headache)..
Old 02-17-2010   #22
Re: T-case bracing?
Why doesn't your homeboy Rau fab one up for you?
Old 02-17-2010   #23
Re: T-case bracing?
har har har. Rau doesn't do everything for me, jesus. Besides, he doesn't even know what a t-case is
Old 02-17-2010   #24
Re: T-case bracing?
When you are close to running their times then I think it could be a valid point to consider doing this. Until then you need to first get your car together, running correctly and down the strip because you really need to stop kidding yourself and everyone here about how awesome your car is/will be.
Old 02-17-2010   #25
Re: T-case bracing?
/thread
Old 02-17-2010   #26
Re: T-case bracing?
I'm not kidding anyone. What's wrong with doing research, and trying to prevent anything from going wrong? I swear every time I raise a question unasked by others, I get shit from assholes like you. Don't like the question, then keep your opinion to yourself. Not once did I say I was fast, cool, or anything. Last I checked the ownership of the car was MINE, not yours.
Old 02-17-2010   #27
Re: T-case bracing?
^lol. I think he is just dishing it back, so get off your high horse big turbo slut.
Jake's car exploded cause his Tcase locked up I thought? I don't know nothing about mr BB. I know who you are talking about on talk, but I think you should run the car a bit first.
I'll let you know if I find out anything, but that shit is too high HP for me.
Old 02-17-2010   #28
Re: T-case bracing?
Of course you're kidding people. You are looking into a modification that you don't even know your car needs for sure. For all you and the rest of us knows your car will never see the track! This thread is on the same level of ridiculousness as if I were to start a thread about putting a roll cage in my car because I want to stiffen up the chassis and I'm afraid of it rolling over at autocross because I might get sticky tires... some day.
Old 02-17-2010   #29
Re: T-case bracing?
Don't forget the blinker fluid reservoir bracket bracing to! j/k!!
I agree, swifty, get the car running down the track first
Old 02-17-2010   #30
Re: T-case bracing?
Still thinking about getting a parachute?
Old 02-17-2010   #31
Re: T-case bracing?
Fine, nevermind. I'll just run it, and shut you all up. Blow it up, whatever.
Old 02-17-2010   #32
123abc
wants to be sideways...
123abc's Avatar
Drives: Loud cars
Re: T-case bracing?
And that's the key. Don't be afraid to break shit. :P
Originally Posted by Matt D.
Originally Posted by 93GSX5SD
Old 02-17-2010   #33
Re: T-case bracing?
I think he's going to use zoobas?
or was that turbotalon1g
Old 02-17-2010   #35
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
Re: T-case bracing?
Just get another one for a backup. They are cheap enough and easy enough to install where it wouldn't be a big deal if you messed one up. If you happen to break yours, maybe you can spend a little time beefing up a second one. I wouldn't worry about breaking it just because a select few people have especially with how cheap they are. Just my opinion though.
7/25/09
Old 02-17-2010   #36
Re: T-case bracing?
Dont forget to run a brace that braces the brace. Also put a brace inside the parachute.
Old 02-17-2010   #37
Re: T-case bracing?
Try contacting these guys.
Old 02-17-2010   #38
Re: T-case bracing?
Waste of time. I split mine in half at the shootout in 2001 or so, that piece of shit brace pictured wouldn't help with squat. You'd have to brace it from top to bottom and side to side on the front of the case, where the gears mesh at the 90 degree angle. There's not room to do that under the oil pan so it's a moot point. Keep a spare in the trunk and call it a day.
Old 02-17-2010   #39
Re: T-case bracing?
we actually talked about this one night in SB, i mencioned how he seems to have gone through more turbos than myself, but we counted it out and i have seen more turbos, but i supposed he can be called turbo slut and ill be Turbo Whore.
Old 02-17-2010   #40
Re: T-case bracing?
