Old 04-28-2004   #1
v8klla
v8klla's Avatar
Just got my GSX on the road, and I have a few small problems to sort out. One being that the car kills in tight cornering, it is almost like it is rubbing somewhere or something in the drivetrain is catching. If I give it gas it won't kill, but if I let off it will either die or if I hit the clutch the car comes to a stop by itself with no braking.
I know there is an LSD in the rear diff, but I don't think the car should stop on its own while turning or die in tight turns. A friend drove it and said it felt almost as if it had a welded viscous. Being new to AWD I have no idea. But I don't think the guy before me would have had that done.
Also on the highway the rear end seems to sway or wobble at times, the steering wheel stays straight but the back end gets thrown out. It's almost as if it is fighting against itself in terms of alignment?
And finally the car has been running really hot, DSMlink has the fans on all of the time and they are working. The coolant is full as well. I don't know why it is heating up so much, the coolant light is on in the car though? Bad thermostat?
Any ideas?
Thanks much,
Chris Carey
Chris Carey, President
Modern Automotive Performance
P: 763-545-3800
E: chris@maperformance.com
