Old 04-06-2011   #21
Re: MR2 in the making
That's the same as a MKIII Supra right? What all is done to this thing anyways? I didn't see a modlist. I know my poopra buddies say the turbo outlet/elbow (equivalent to a DSM/Evo o2 housing) is a pretty big gain on their cars, same for MR2's?
Do you plan on upgrading the stock turbo some day or just having fun with it as is?
Typically people will just upgrade the downpipe completely instead of an outlet. The dual scroll design means that the "o2 housing" is huge and a giant mess of exhaust area.
This reminds me I need to update my thread, maybe tonight when its on the road finally.
Old 04-06-2011   #22
b00sted_spyder
MKIII Supra's CT-26 turbo is different than the 3SGTE's CT-26. The downpipe flange are different and the 3SGTE have twin entry wastegate flapper instead of one flapper.
My plans are just basic bolt ons(intake, intercooler, exhaust, downpipe, etc..). Maybe some cams in fall or next winter. As for turbo, still undecided. I will definitely be using this CT-26 this summer. Maybe as big as a GT35r but that'll be in a year or 2. I wish there was an affordable simple tuning system link how we have ECMlink for our DSM.
Old 04-07-2011   #23
A used AEM ems would be a good deal. And you can make any version work as long as it's from a 4 banger and you get the harness.
Old 04-07-2011   #24
There is actually a PNP version. I've tuned on on a MR2 and one on an AllTrac (same box if memory serves correct)
Old 04-20-2011   #25
b00sted_spyder
A little update. I got a few layers of white primer on the front bumper but need to go buy more primer. Found a cheap set of euro lights. Will be picking up a wideband this week and solid side moldings next week. In a few weeks I'll be ordering my OEM parts and I should be able to install the bumper and tail lights. I also got some of the side moldings pained. Just need to paint the passenger side vent and door moldings.
Euro signals. Thinking about getting some amber LED for the clear part.
Old 04-22-2011   #26
kgx
Drives: MR2 turbo
make that 4 MR2s i was on dsmstyle years ago. i just lurk here mostly.
I run a chipped honda ECU on mine. $150 engine management baby. I did a write up on it over on mr2oc a few years ago.
kgx is offline   Reply With Quote
Old 05-16-2011   #27
b00sted_spyder
Got some of the OEM parts in today. L brackets came with it so I was ready to install the kouki tail lights.
Bumper put on to just test fit. Need to buy the solid molding and wait for the license plate bracket to come in.
The hose couplers that came with the intercooler kit weren't the correct size. I'm guessing that's the cause of it to not stay idling. I will be ordering a 1 piece Berk Tech cold pipe to replace the 2 piece. That'll be 1 less coupler and 2 t bolt clamp to worry about.
Old 12-15-2011   #28
b00sted_spyder
It's been a while since I've touched this thread. Here's 2 photos from October before the MR2 sat in the garage.
Old 12-15-2011   #29
b00sted_spyder
Picked up some OEM side vents. Much more cleaner looking than before.
Installed today.
Just an ass shot
To be continued...
Old 12-15-2011   #30
At-Least-It's-An-Evo
At-Least-It's-White-Again
At-Least-It's-An-Evo's Avatar
Drives: 98 iVTEC
gettin rid of those blitz 03's? They may fit my s2000 nicely
'04 Honda Ricer: stock
Old 12-15-2011   #31
b00sted_spyder
They can be for sale if you're interested.
Old 12-15-2011   #32
Looks good!
Old 12-15-2011   #33
Nice, i like those rear wheels.
Old 12-16-2011   #34
123abc
wants to be sideways...
123abc's Avatar
Drives: Loud cars
Car looks really clean. Love MR2's. Are the side vents actually pretty efficient in allowing air to get to the intercooler?
Originally Posted by Matt D.
Originally Posted by 93GSX5SD
Old 12-16-2011   #35
Looking good, going the megasquirt setup with the custom crank pickup?
Old 04-19-2012   #36
b00sted_spyder
Picked up some top feed FIC 1150cc injectors for a steal. I'll be using a Camry fuel rail since the Mr2's uses side feed style.
Old 04-19-2012   #37
I like where this is going!
Old 04-19-2012   #38
Andrew7dg
Built it from scratch!
Andrew7dg's Avatar
Drives: Currently Mitsu-less
You should still be able to use the sensors in the distributor instead of going with a custom crank setup. It should be a VR sensor type which MS can pick up.
There should be like 3 sensors in the distributor if memory serves me.
24 or 36 tooth - i can't remember how many tooth there is but it is there
4 tooth
1 TDC tooth
Just take apart the distributor to see what wires feed what.
You can tap into one or two of those. I recommend using the TDC tooth for one input and one of the multi tooth input for the other. You should be able to pick the wires up by the stock ECU if you have a pin out chart.
I helped out on putting a 20v in a mr2 MKI and went with the custom crank setup tooth wheel.
I wish we went with the distributor! it would have made our lives a lot easier. The multi tooth wheel by the crank looses signal. I blame the bracket that the hall sensor sits on. Need to better engineer that. after that it will work just fine.
However it would have been MUCH easier to tap into the distributor instead.
PS later down the road you don't even need to use the distributor for your ignition! You would be using it like a cam sensor instead.
the 20V is running a DSM coil pack controlled by the MS2. Works VERY well and is an ignition upgrade compare to what was there.
the 20v 4age and the 3sgte are not all that different. both have cylinder heads from YAMAHA
Old 04-19-2012   #39
MS2? Nice, this site needs more MS powered cars
Old 04-19-2012   #40
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
nice, very sweet project man
2006 WW IX RS 396/404 - SOLD
