Old 11-30-2011   #21
Re: Carl's 98 auto AWD project Black Magic
After talking to Dan it sounds like you need the 2.0 to flash the stock 97+ ECU
Old 11-30-2011   #22
Looks nice! I had those wheels on my 1g, I say leave them silver!
Old 11-30-2011   #23
carltalon
carltalon's Avatar
Drives: 98 Eclipse GSX Auto
A little update. I traded my 1g dsmlink for a 2G link V3 setup with no ecu. So I might be going to go dsmlink in this car. I still need to find a eprom ecu. I still want to do the ecu flash rought though so the dsmlink setup is for sale we'll see what happens
I think the silver is growing on me too, we will see. I got the lug key from the previous owner so I might swap on the black cobra's just to see how they look then add a poll.
Originally Posted by jeffescortlx View Post
Stop holding out, and post up that pic of the Chicago Pizza that made the 6 hour one way drive a little better. Damn that was some good pizza.
The pizza was awsome I'm ready to go back for more any time.
ID:	12132   Click image for larger version
ID:	12133   Click image for larger version
11.35 @ 120mph
Old 12-06-2011   #24
carltalon
carltalon's Avatar
I did a little research and found that the Haun racecraft o2 eliminatoir downpie I had on my laser will fit on a 2g. So today I pulled the downpipe and dumped O2 housing off and test fit the HRC. It actually fits better then the one that was on the car and should be less restrictive. Best part, no more wastegate dump!! 2g downpipe and dumped O2 housing will be added to my partout thred.
11.35 @ 120mph
Old 12-28-2011   #25
carltalon
carltalon's Avatar
I Picked up MunchGSX's MAP EF1 last night. So I am very excited to start modding this thing. I still have some parts to pick up but Its a start.
Goal for this summer will be 11.99 with the child seat in the back.
My Parts so far.
EF1
HKS 272's with Adj cam gears
Best MOD so far. Child seat
11.35 @ 120mph
Old 12-28-2011   #26
haha awesome! That EF1 is gonna make for a fun-ass lil 2G!
Old 12-28-2011   #27
me likey.
Old 12-28-2011   #28
19TsiAwd90
2stepadepaaadepaaadep
19TsiAwd90's Avatar
Drives: myself crazy
went with link instead of the open port i see. any particular reasons? probably just easier to use i guess.
Originally Posted by 311evo
Old 12-29-2011   #29
carltalon
carltalon's Avatar
I traded the link from my 1g that I'm parting for the 2g Link so I'll probly go that way. The 2g setup is for sale so If it sells I'll buy the openport cable and have money leftover for the injectors I need or parts to sure up the auto trans. I'd like to stick with Link just because I already know how to use it and it has a few features that the flashed ECU wouldnt.
11.35 @ 120mph
Old 12-29-2011   #30
Looks like you have some fun ahead of you!
Old 02-26-2012   #31
carltalon
carltalon's Avatar
I picked up a few more parts, and am getting pretty close have ind everything I need to meet my goals.
2G hard intake pipe with mass and filter.
MAPerformance 7 bolt head studs with dog point tips.
2g FMIC with pipeing.
I was planning on seeing how far I could push the supra sidemount But I picked this kit up pretty cheap and sold the sidemount for enuf that I basicly swape.d to a fron tmount for the same price it would have cost to get the J-pipe i needed to use the sidemount with the EF1. The intercooler is a little small for my tastes, but is probly plenty big. I can always use the pipeing and upgrade the core in the future.
I'm still in need of a few parts if anyone has what I need.
injectors (1000cc +)
2g EPROM ECU
1g style turbo oil return.
translab shift kit
End clutch kit
PICTURES
Intake (with box o parts)
Headstuds
Intercooler
Car sleeping in the garage awaiting the transformation.
Old 02-26-2012   #32
hmmm nice.
You can find the translab kit on line for stupid cheap:
http://motors.shop.ebay.com/i.html?_...ts_Accessories
Old 02-26-2012   #33
carltalon
carltalon's Avatar
hmmm nice.
I've been looking for those. but to get the drill bits and the newer check valves you need the TL-175-HP I can only fing the non HP kits on ebay. its probly worth the extra money to not have to chase down the bits. unless some one already has the drill bits.
11.35 @ 120mph
Old 02-26-2012   #34
carltalon
carltalon's Avatar
hmmm nice.
Aaron do you have the part number of the end clutch kit your running?
11.35 @ 120mph
Old 02-26-2012   #35
Contact munchgsx/MAP he has the number.
Old 02-26-2012   #36
carltalon
carltalon's Avatar
Will do.
I found the HP kit for $50 on ebay might have to go with that. http://www.ebay.com/itm/All-KM-OD-Hi...item2eb13565d5 I like the $28 price better though.
11.35 @ 120mph
Old 03-10-2012   #37
carltalon
carltalon's Avatar
I did some work on the car today. Mostly electrical work.
Installed 95 EPROM ECU with DSMlink V3
Cleaned up some of the ECU wireing done in the past.
Installed my LC1 wideband and wired it into the ECU for loging
Reinstalled the Brake Switch controled relay for launch control
Wired up the relay for ECU controled full line pressure to the auto trans
I also removed the T25 turbo. Swaped the coolant lines to the EF1 and modified the oil drain to work with the EF1. Just need to pick up a turbo gasket set and oil feed and the EF1 and my ported 2g manifold will be ready to go in.
the car started and idled on the new ECU setup and I could conect with the ECU so everything seams good. I can not wait to get this thing out on the roads and feel the Magic.
11.35 @ 120mph
Old 03-11-2012   #38
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
What does the brake control switch for launch control do? Did you find a end clutch kit yet? I think I'm gonna replace mine too.
Old 03-11-2012   #39
carltalon
carltalon's Avatar
The brake switch is used to activate the NLTS function on DSMlink. http://www.dsmlink.com/forums/showth...ke+switch+auto
I havent found a end clutch kit yet. Ive been looking a the alto kit 059935PWR But havent found any deals yet. Also looking for the raybestos kit IPT sells but havent found the part number yet.
11.35 @ 120mph
Old 03-11-2012   #40
Why do you use the NLTS?
