Old 03-15-2012   #21
Re: 91 Galant VR4 #597 Project redemption
Well shitty about the motor, but nice u got it up and running.
U just gonna move the AEM between cars then?
Old 03-15-2012   #22
No, lucky for me I have 2 aems.
Old 03-15-2012   #23
Old 03-15-2012   #24
Sweeet Did you actually dyno it or just guess? Cool that she's up and running!
Old 03-15-2012   #25
Virtual dyno for street tuning.
1.00 correction, it is a start.
Old 03-15-2012   #26
Yes mass vs acceleration, with engine rpm, tire size, and gear ratio it should be darn near as spot on to a dynojet. It might make the spring dyno day to confirm.
Old 04-06-2012   #27
I have put 600 miles on the car. The turbo is just about toast so I will be installing a mutt level 1 turbo and some 760cc injectors I picked up. I am also going to swap in a spec stage 3 clutch or similar and a set of stock cams.
Also a set of tires and better suspension will make it a better driving car.
Old 05-06-2012   #28
I did get 1100 miles on the car.
But now the knock off 16g is shot, it does not make much boost anymore. And with the race car needing a few things back to get up and running I picked up a Spec stage 3 clutch, Evo 8 FMIC, and I will swap the cams, cam gears for stock units, and pull the shims out of the valve springs.
And I want to pick up a set of stock 2g wheels or something for the car, right now I am borrowing a set of rims and tires from a friend.
So the goal for the car is better drive ability, better MPG, and less bangs/rattles, and hook up the power steering again.
Old 05-06-2012   #29
I agree with all of those goals!
Old 03-16-2013   #30
Time for a small update.
I have finally made progress on this thing. Its up and running with the MUTT 1 turbo, 17psi on pump gas with the back up race motor, spec stage 3 clutch, winebro FP, AEM EMS vs 2, etc.
I figure its making about 260ish AWHP and has been a decent DD for 2000miles.
My next plans are install EBC, put the PS back in, buy a set of wheels for my 15" drag radials for summer use, and I might even track down AC parts.
I also installed a babe seat car base if I need to haul little Liana anywhere I am set to do so.
