Old 06-20-2012   #21
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
Re: What Kind Of Oil Do You Use/ Recommend
http://www.mitsustyle.com/forums/sho...ght=Oil+brands
Can't find the original thread but this was a sticky
Old 06-20-2012   #22
FWIW, I've always ran Rotella and Amsoil high zinc.
Last I heard Forced Performance won't even warranty a turbo ran on Mobil1. I've also had a few of the knowledgeable locals who deal with high hp engines all day every day tell me to stay away from Mobil1, and they have seen more cars run spin bearings on that oil than anything else. That means more to me than any random internet forum guy's opinion and is why I've never used it.
I think super bleeder already posted it, but it's worth reading.
http://store.forcedperformance.net/m...otor%20Oil.pdf
Old 06-20-2012   #23
Well, if you want to play that game, Cobb has seen more Subarus spin bearings on the track running Amsoil than they have Mobil 1. When it comes down to it, none of this matters because it's not scientific data and doesn't take into account the percentage of total population running said oil, the setup & tune of the car, other factors that could play into it, etc.
Old 06-20-2012   #24
Look at the tests, Mobil 1 is usually near the top. One thing to think about is the longevity. Do you think amsoil or mobil has more research in to their additive packages? What oil comes stock in most of the super cars? I'll stick with Mobil 1 in my cars.
This; exactly my thoughts.
stick with regular change intervals, stick with recommended weights, and leave the science to the manufacturers because they know a million times more than I ever will.
Exactly my plan; pick a reputable brand and admit their team of engineers and scientists know far more than I'll ever even dream of learning when it comes to this stuff.
I'm also willing to bet than when running the proper viscosity oil with proper change intervals, if a failure occurs with one reputable oil the same would happen with any other reputable oil. At best, a different oil could delay the inevitable, at worst, it would have happened sooner. Realistically, it probably would have happened at the exact same time though.
I also think this whole internet craze of "OMG more zinc!" is ridiculous. Zinc is just one of many anti-wear additives available and some oil manufacturers are choosing to go with others for various reasons (including emissions). For example, both Castrol and Mobil are using titanium dioxide more heavily in some of their newer oil formulations. Personally, I could careless which they use since they all serve the same purpose.
Old 06-20-2012   #25
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Honestly, I am guessing correct oil weight has more of an impact on whether or not you spin bearings.
Thousands have spun bearings on every kind of oil...I don't think there is anything wrong with Mobil1 at all. For a stock motor, mobil 1 worked awesome for me.
FWIW the AMSoil high zinc I am currently running is what I was running in my first built motor that spun the bearing...so if anything that helps your statement. However, I don't trust Cobb for shit due to recent events and I think they are tool's. And just because one shop (regardless of shop) says they have seen more failures on said oil, well like some have said, doesn't really mean much. However, both MAP and DB stock and recommend the AMSoil high zinc I use so I know its not a bad oil, tons use it on the national boards as well for built motors.
I know one thing, High zinc content and correct weight are what I care about as I know for fact that is good for a built motor. Also I ran Rotella on this motor and its still kicking great for breakin as a sidenote.
Old 06-20-2012   #26
Scheides is going to have to break oil discussion off into it's own sub-forum then eventually delete it and ban it's discussion all together like politics
Old 06-20-2012   #27
Back when i got my last GSX, the first oil change i did (wasnt sure how long the last one was), i tried Redline Oil. So expensip, but i guess it was good. Kinda like a microbrew of oil in the grand scheme of things.
So who runs Fram Filters here? Because based on some of the logic here, Mass production yields better results every time. (adds fuel to fire)
Old 06-20-2012   #28
GsXtUrBo98
GsXtUrBo98's Avatar
Drives: 98 GSX, 04 is300
Ams oil 10w 40 high zinc with wix filter
98 GSX (built)
03 BBY EVO dd
GSX 463awhp 363awtq on DB!
Old 06-21-2012   #29
123abc
wants to be sideways...
123abc's Avatar
Drives: Loud cars
I run mobil 1 10w30 in the warmer months, 5w30 in the colder months. No other oil filters besides wix oil filters will touch my car.
Originally Posted by Matt D.
Originally Posted by 93GSX5SD
Old 07-13-2012   #30
lucasoil4u
Drives: talon tsi evo 3 25psi
Rotella T6 5w40 Synthetic. It doesnt get full of soot like other oils. Works great!
Mitsubishi.... Special Cars for Special People.
lucasoil4u is offline   Reply With Quote
