Old 10-13-2013   #21
M1L3S
M1L3S's Avatar
Drives: 99Gst
Re: head fused to the block ?
https://www.youtube.com/watch?v=TrAV...e_gdata_player
Made a video.
M1L3S is offline   Reply With Quote
Old 10-13-2013   #22
M1L3S
M1L3S's Avatar
Drives: 99Gst
I have no clue why it won't come up.
Old 10-13-2013   #23
You need to get all of the head bolts out before the head will come off.
Are you sure you are using the correct hex head to get the bolts out?
Old 10-13-2013   #24
The easy way to get them them out now would be get a stud remover socket that will fit on them with the head on it still
Old 10-13-2013   #25
M1L3S
M1L3S's Avatar
Drives: 99Gst
Yeah I bought a 3/16 socket Allen head.
Old 10-13-2013   #26
M1L3S
M1L3S's Avatar
Drives: 99Gst
The actual stud itself?
The nuts/bolts are off
3 of the allen heads are rounded on the stud itself.
What would the stud tool grip onto with the head still on and only 1/4 of the stud exposed?
Theres seriously some kind of black magic keeping this damn head on
Old 10-13-2013   #27
twack
It was a auto get over it
twack's Avatar
make sure all the washers are off as well. ive stripped out one of the allens on a arp and i pounded a torx bit into it and prayed, and i i managed to get it off. i really can imagine the head studs swelling and being your issue. 123abc's car blew a head gasket and he drove the 20 min remaining to my house and the head had melted between cylinder 2 and 3. so i guess with that heat, possibly it warped the head and block to the point that the studs are no longer standing straight. But i think its stuck on the dowels
Old 10-13-2013   #28
Mark Leasure
Mark Leasure's Avatar
Just speculation, the head is badly warped and interfering with the studs.
www.maperformance.com
Old 10-13-2013   #29
enasnitsi
Drives: 1993 Talon Awd
I'm pretty sure the studs have a 5mm socket head not 3/16. That didn't help with stripping them out.
That head probably isn't going to be to good after it got that hot. I have seen ones with a lot of damage after getting that hot.
enasnitsi is offline   Reply With Quote
Old 10-13-2013   #30
4seasons69
4seasons69's Avatar
To get the head studs out get a set of bolt extractors. Pound an extractor on and hit it with an impact. This will ruin the head stud but should get it out.
Old 10-13-2013   #31
dsmreck
dsmreck's Avatar
Drives: 98 gsx
^ what he said. thats what we had to use for my oil galley plugs on my block. very cool.
Old 10-14-2013   #32
Sure there isn't a bolt holding the water pipe to the head? I missed that once.
Old 10-14-2013   #33
M1L3S
M1L3S's Avatar
Drives: 99Gst
No bolts. But in all honesty head stud #4 is completely stripped at the top. The washer wont budge. I think that one is the issue?
All the washers move around on the stud (I dont have a magnet strong enough or anything to get them off :/ )
All of the studs broke loose before a few stripped at the top. But that one wouldnt move at all.
Old 10-14-2013   #34
Thats probably your problem then. That one is at the end of the block right? does the other side wiggle even a little? Not sure, maybe drill it out somehow or something, or see some of the suggestions above...
Otherwise....thermite?
http://www.youtube.com/watch?v=rdCsbZf1_Ng&hd=1
Old 10-14-2013   #35
Does this thing have studs or bolts? You have mentioned each about 15 times.
Old 10-14-2013   #36
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
If they are arps. Can't you just tighten two nuts together on the end of the stud and then try to get off that way? Worked when I did it.
Old 10-14-2013   #37
dsmreck
dsmreck's Avatar
Drives: 98 gsx
i was going to suggest that but he said only 1/4 inch sticking up.
i would try a magnet on one side and a pick on the othr to help lift washers up.
Old 10-14-2013   #38
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
BFH!
Old 10-14-2013   #39
M1L3S
M1L3S's Avatar
Drives: 99Gst
The block has arp head studs. I removed all ten of the bolts that go onto the studs. But was unable to get the washers off of the studs themselves (so they are still sitting on the studs in the head). I was able to loosen and remove a couple of the actual head studs.
A few of the studs are stripped out and still inside the block.
But all bolts that hold the studs in place and apply the clamping force are removed.
Are 6 bolt arps 13mm head bolts ? Because my block has some weird stuff going on im discovering.
Sorry for the confusion. I mix alot of words up all the time. Im that guy.
Old 10-14-2013   #40
mondale
Drives: 1g dsm
Bolt
Nut
Stud
Do you have a welder that you could use to weld a nut onto the stud after screwing it on until just about even with the stud head?
8.59 @ 158
mondale is offline   Reply With Quote
