Old 01-22-2015   #21
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
Re: Andre's 2g GSX build
Nice liking the RX7, looks to be in pretty nice shape
2006 WW IX RS 396/404 - SOLD
Old 01-23-2015   #22
b00sted_spyder
Proven force should be able to build a driveshaft for you depending what your needs are. I know we don't have fixtures for dsm flange and slip yoke but DSS driveshaft are 1310 series. Pretty much need to convert to the 1310 slip yoke, end yokes, tube, joints, and the adapter that DSS sells to connect to the rear shaft.
Old 01-23-2015   #23
Dark2g
Drives: 2gb gsx
So would it save me money vs just going with a complete dss setup or what would be the benefit be of going with proven force? How about the carbon fiber ones that dss sells? Anyone know if they are worth it or what the benefit is there?
Old 01-23-2015   #24
b00sted_spyder
DSS driveshafts are overrated. I've seen a DSS wrx shaft come in and it had a ton of runout. Either they built it like crap or the owner really fucked it up. The welds weren't even nice looking. 799.99 is a lot for an aluminum 3" 1310 series. Keep in mind that it only eliminates the front hanger. So instead of a 3 piece shaft, it'll be a 2 piece reusing your last section with the hanger. With the 300m output shaft, i believe it takes a c4 slip yoke from a ford which is a 1310 series joint. It takes a much bigger joint than the dsm joint. We are also starting to sell CF driveshaft. But it is not built in house. They are glued to the aluminum end yokes. Very precise driveshaft. But once it goes bad, it's garbage.
Old 05-23-2015   #25
Dark2g
Drives: 2gb gsx
Installed my new built trans here a month ago and finally got some fuel. Went to brained with my wife and kids for a Wednesday night and made a couple passes. Tune needs work and I didn't have time to mess with it well I was there. I had some pretty pathetic launches, assuming because upgraded center and front diffs that I just wasn't breaking loose like before. First two passes I only ran out the third and on my third I tried fourth out. Tech guy was pretty bummed so I just called it a night and was glad to load a working car!
Old 05-24-2015   #26
carltalon
carltalon's Avatar
Drives: 98 Eclipse GSX Auto
Nice MPH. When you get it to 60ft it's going to be a beast.
11.35 @ 120mph
Old 05-24-2015   #27
Mark Leasure
Mark Leasure's Avatar
144MPH is moving along! The tech guy was bummed? Did he end your night due to the 11.2 pass?
www.maperformance.com
Old 05-24-2015   #28
Dark2g
Drives: 2gb gsx
Thanks and yes the car is unreal in 3-4. Hope I can get some work done in 1-2 and it should be real fun. It needs a cage and yes tech was upset about mph more then the time. It was my warning and I just went for a little quick fun. Still want to get to play at pg and stuff this summer. Now that I have been able to get my coolant temps fixed with that half radiator I have actually been driving it around a little bit here and there and it makes me even more hesitant to put a cage in it.
Old 05-25-2015   #29
Bring it down for some street action!!
Old 05-25-2015   #30
carltalon
carltalon's Avatar
Do it... That will definitely get me off the couch.
11.35 @ 120mph
Old 05-25-2015   #31
In for some street action!
Nice runs too. Always good to go home with a working car
Old 03-30-2016   #32
Dark2g
Drives: 2gb gsx
Well just about got my car all back together. Ended up having a few
issues last fall including my transmission popping out of reverse, my twin disc
needded a rebuild and needed to change out a coolant line cause the way I welded the -16 bung on. So rebuilt the ptt clutch, replaced the wave spring, installed a CNC handbrake, still working on the brake lines, a Magnus launch controller, redid -16 an shortened a coolant loop that was driving me crazy, installed the dss axles, now I really Would like to deal with the wiring. Would really like the have lms efi make me a harness. He made one for my adaptronic setup for my rx7 and the quality is amazing and makes it look so clean. Either way new barrel of e98 on its way and should get to go take it out next week. Really plan on getting it on the dyno at db this spring before I get sidetracked with other projects. Hoping to also switch out the wheels for a rpf1 setup
Old 04-03-2016   #33
carltalon
carltalon's Avatar
Cool. I was afraid this car was tucked in the back of a shed or parted like alot of other badass DSMs. Keep up the good work.
11.35 @ 120mph
Old 04-04-2016   #34
Excited to see this out and about all sorted.
Old 04-06-2016   #35
evotuner
evotuner's Avatar
Drives: 2004 Evo 8
Very cool project, anymore pics of this beast?
Old 04-06-2016   #36
Dark2g
Drives: 2gb gsx
Then a repainted it this last fall
And some Mazda for fun with the new paint, wide body, and some ssr love!
Old 04-06-2016   #37
daaaaaaaaaamn
Old 04-06-2016   #38
GsXkingGsX
GsXkingGsX's Avatar
Drives: 1997 Eclipse GSX
Send a message via Yahoo to GsXkingGsX
christ
'97 Eclipse GSX
GsXkingGsX is offline   Reply With Quote
Old 04-06-2016   #39
So pimp
Old 04-07-2016   #40
:giggity:
