Old 04-06-2015   #21
Re: UBER SS
Revs quick for such a big engine!
That Pro-Systems carb works very well. That's out the box.
Old 05-05-2015   #22
Re: UBER SS
I forgot to post pics of the installed radiator and cooling fans. Fits well and looks great.
Installed a new Stewart Stage II cooling pump this weekend.
Very well made and not that expensive as compared to others (Edelbrock ).
Took a quick look inside and found a nice cast impeller instead of stamped steel.
Old 05-05-2015   #23
Re: UBER SS
If you're having cooling issues, wonder if it might help to have a shroud for the rad/fan?
Looking badass though man!
Old 05-05-2015   #24
Re: UBER SS
The radiator and fans fixed the heat soaking which occurred while driving at cruise/higher speeds. I'm seeing roughly 3400-3500rpm at 60-65mph.
Those are the Zirgo Ultra Performance ZFU14S fans. They pull almost 2800cfm each.
The pump was an original GM cast iron unit which is under driven a good bit and didn't pump enough at idle, causing heat creep sitting in traffic.
So the rad/fans fixed the cruise temps issue and the pump fixed the extended idle issue while shaving a few pounds off the front of the car.
Old 05-06-2015   #25
Re: UBER SS
Such a clean engine bay, I like. Glad to hear the heat issues are resolved.
Old 05-06-2015   #26
Re: UBER SS
Thanks. So far so good on the heating issues.
Old 06-21-2015   #27
Re: UBER SS
Shit getting real,...
Say hello to my little Friend. It's not little, but ya get the point.
Old 06-29-2015   #28
Re: UBER SS
Busy weekend, but going well,...
Out with the old,.....
Obligatory "glamour shot", LoL,.....
In with the new,...
Old 06-29-2015   #29
Re: UBER SS
Whoa, sexy.
I'm still for an LSx and a set of big hairdryers though.
Old 06-29-2015   #30
Re: UBER SS
Whoa, sexy.
It was a hard decision not to go that route. My biggest concern was about adding weight to the front end (turbos, heavy manifolds, intercooler, piping, etc.). Right now I'm at 56/44 split to the front. Any more weight that shifts the balance to a heavier front end would only make it harder to hook up. I've seen several LS swaps into muscle cars and they just look out of place so I decided to stay BBC. Nothing sounds like big cubes with a big cam.
But, if I ever get the itch, there's enough nice parts in this one that dropping the compression ratio and a cam change could allow for some serious powa!
Imagine a 582 on boost!!
Old 06-29-2015   #31
Re: UBER SS
Oh so pretty!
Old 06-29-2015   #32
Re: UBER SS
So, I'm kind of an idiot with older stuff. What is it?
Old 06-29-2015   #33
Re: UBER SS
Scott Shafiroff 582, Dart Big M 9.800 deck/4.600 bore block, Callies Dragon Slayer 4.375 crank, Manley 6.535 H-beam rods w/ARP2000 bolts, Mahle coated forged pistons 10.8 to 1 comp, Dart Pro 1 heads CNC combustion chambers at 114cc, 2.30 and 1.88 valves, Harlan Sharp rockers, Straub Technologies hydraulic roller custom ground to match head flow numbers, Morel roller lifters, Wilson Manifolds (Merlin X) intake, Stewart Stage II water pump, ATI balancer, Milodon pan, in the neighborhood of 850hp/700tq on 93 oct pump gas, plus 300 shot of nitrous (150+150 dual stage),.... OH MY!
Old 06-29-2015   #34
93gtpeater
Drives: cbr 1000rr repsol
Re: UBER SS
Great choice. Nothing can beat a bbc with a big old cam. Plus n/a motors are pretty reliable and constant. Throw some spray on it and shit gets real. That thing should be in the 9s on motor if you can set up right. Please post a video when you get it running.
Old 06-29-2015   #35
cmspaz
Walls need hugs too
cmspaz's Avatar
Re: UBER SS
Hook at the line hard enough and you'll get all the weight on the rear tires.
Originally Posted by Trogdor
Old 06-29-2015   #36
Re: UBER SS
That's what I'm hoping for. I'll post vids as they become available.
That must happen first,.......
4-link set-ups like a 55/45 split at minimum, so it's already a little nose heavy. Hoping those aluminum heads pull a little off the front weight, normally they would knock off about 70lbs, but that Dart block throws some back in the mix.
Old 07-02-2015   #37
Re: UBER SS
It's alive!!
http://www.youtube.com/watch?v=loCoutD9HkU&hd=1
Old 07-02-2015   #38
GsXtUrBo98
GsXtUrBo98's Avatar
Drives: 98 GSX, 04 is300
Re: UBER SS
That is one sexy machine!
98 GSX (built)
03 BBY EVO dd
GSX 463awhp 363awtq on DB!
Old 07-02-2015   #39
Re: UBER SS
Thanks, it gets the job done.
Old 07-02-2015   #40
Re: UBER SS
Wow, you weren't messing around ordering that motor. Geez, she should go real nice. 9's on pump gas!
