Old 04-04-2015   #21
Re: Over Boosting? Need some help guys
30psi is a ton of boost creep, wow.
Did you try hooking the actuator directly to the intake manifold vacuum source?
Old 04-05-2015   #22
1990GSX
Drives: 1975 corvette stingray, 2008 evo x gsr
Edit: I missed this post:
Originally Posted by talonsway View Post
so i removed the arm and took it for a drive, at about 4-5k i was seeing about 20 pounds of boost and at about 6/6.5 almost 30 pounds of boost. So if i am thinking right this means i found the problem, and that is that my waste gate is bad? So start shopping for a big 16g Waste gate actuator?
Do this:
1990GSX is offline   Reply With Quote
Old 04-05-2015   #23
talonsway
Drives: 1995 eagle talon TSI
Boost source will be going to the intake next. with that flapper open like i had it. Shouldnt i have not been able to boost at all?
talonsway is offline   Reply With Quote
Old 04-05-2015   #24
1990GSX
It should have been as low as you can physically go if you were sure the arm was removed and flapper stuck actuated to have the wastegate channel open. That is why halon was saying if you still were getting creep with the wastegate fully open changing the actuator will not help cure your problem. You will need to enlarge the wastegate so you can vent off more air.
The steps people want you to take are as follows:
1. Open wastegate fully check air flow by disconnecting rod/actuating flapper. Once you confirm you can flow enough air to avoid the boost raising above your target point then go to step 2. If you cannot flow enough air you know this is your problem.
2. Hook actuator back up to compressor source without mbc installed. The boost should build to the point in which the spring holding the wastegate flapper is overcome by the boost pressure. The wastegate will then open and start diverting exhaust gases away from the turbo. If this works correctly and only creeps to a stable amount like the 20-21 psi shane said then you know this is going to be your boost level unless you set the mbc higher. You can then go to step 4. If your still getting a problem after this you can check the following: actuator arm stuck/not working bad actuator or go on to step 3.
3. Hook actuator up to inlet source. If this fixes your problem then it was something with the source. Go on to step 4.
4. Install mbc. Set boost level. If you set it below the 20-21 psi (or whatever psi the wastegate actuator/flapper is allowing to flow) its likely going to creep back up to that anyway. If you set it above it should build to the desired level and hold. If your just spooling building boost as before then you know its your mbc.
Old 04-06-2015   #25
If I am reading this right and the arm was removed to allow the flapper to open all the way right away, then you have bad boost creep. The fix would be a larger flapper and porting or an external wastegate. Another option is to choke the exhaust or intake system so that the turbo has a hard time making boost, which obviously isn't the best option for power.
well I wanted to hold 15 maybe 20 pounds. So if I could get it to hold around there I would be happy. Might just start saving for a external waste gate set up, just drive it like it is because I can not figure out why this is happen. My friends DSM with his 16g and he only boost like 12 and it holds perfect
Being able to hold 12psi fine with a 16G on a DSM is actually weird and not how they normally act. And what his car is doing does not matter and is not going to fix what yours is doing.
Old 04-06-2015   #26
How a 16g could build 30psi with an open wategate flap blows my mind, unless either 1) your flap is welded shut and you don't know, or 2) you are running no exhaust and are giving it more air than any 16g in history. Most barely get over 30 with a basically forced shut flapper.
Old 04-06-2015   #27
Bad boost gauge?
Old 04-06-2015   #28
talonsway
Yes you are right i removed the arm, and gave her throttle and at about 6k had about 25 pounds of boost. Im debating on going with a larger flapper, but would like to go with a external wastage set up. But don't really have the money for that. For a proper external waste gate would you go off the manifold or the o2 housing? And i would need to weld that flapper hole shut.
Old 04-06-2015   #29
Manifold at the collector or O2 housing.
I have an O2 housing built for ext. WG if you ready to buy.
Old 04-06-2015   #30
talonsway
I think i would want to go with a ext. WG at the collector of the manifold not the o2 housing? Ive read that you would need to do porting every time you change your turbo if i went with a ext. WG off the o2 housing. And that people recommend going with a ext. WG off the manifold.
Old 04-06-2015   #31
^Where the fuck are you reading this shit you come up with?
Well it worked for me just fine, I put in 28psi springs and it was rock solid.
Old 04-06-2015   #32
Old 04-06-2015   #33
talonsway
Read it some where on tuners a while back
Bad boost gauge?
Im going to look at how that thing is hooked up. The previous owner installed it.
Doesn't make any sense to me either like at all. The flapper is not welded shut from what i know i can move it with ease. I do have a 3inch turbo back exhaust but it still doesn't make any sense to me. Im going to take it apart this weekend and look into getting some parts.
Old 04-07-2015   #34
If you go off the o2 housing, don't expect it to perfectly fix the boost creep, unless you make the hole in the turbo bigger and port it.
Old 04-07-2015   #35
talonsway
whats a good manifold that's mitsu flanged and has a provision for a Ext. WG? All the ones I see on classifieds and on extreme psi are t3 flanged.
Old 04-07-2015   #36
There is none.
Old 04-09-2015   #37
91talontsi
Drives: Talon Tsi
Wouldnt the solution with the test he did be to port the hole behind the flapper until its close to the size of the flapper? probably a ebay or amazon 16g ive read you have to do this to eliminate the boost creep on them.
91talontsi is offline   Reply With Quote
Old 04-10-2015   #38
If it's a Chinese 16g just get rid of the Damn thing, they are known garbage
Old 04-10-2015   #39
talonsway
not an ebay piece of shit
http://www.dsmtuners.com/threads/evo...%C2%94.163103/
I could...... but i think imma take a different approach.
Imma run a 10cm t3 turbine hosing on my 16g. Then get a nice t3 manifold, with a provision for a external wastegate. Then get a flange for the o2 housing and weld an elbow on it and maybe do a v-band down pipe i have always wanted.
Old 04-10-2015   #40
you are way over thinking this for something so simple
Tags
all the boosts!
