Old 07-20-2004   #21
Enes
Enes's Avatar
how does maft get around that? does it just report a steady temperature?
-E
Old 07-20-2004   #22
Yea on my logger it just stays at a constant 83 degrees so Im not sure if that is the number it uses or just sends it to the ecu differently becuase I assume that the MAF uses temperature on GM vehicles but Im not sure.
Old 07-20-2004   #23
I am pretty sure the translator uses the temp already to make the signal to send to the ECU. So it does get used for the calculation, the ECU just doesn't see it.
Old 07-20-2004   #24
The temp correction is built into the way the GM MAFs work. Our stock MAFs measure air by counting the vortices that the honeycombs create. The GM MAFs heat up a wire and figure out how much more energy it takes to keep the wire at the desired temp, so the temp of the incoming air affects the readings.
Old 07-20-2004   #25
95tsi
95tsi's Avatar
Drives: a pos
I'm getting 32.9lb/min at 80 degree F
Old 07-21-2004   #26
So would it be in our benifit to try to keep out Intake Temps down as low as possible? If so what would be some "realistic" things we could do to keep them down?
Old 07-21-2004   #27
Yes, the more you keep the intake temps down the more power and less chance of detonation. You can either run a cold air style intake or build some kind of scoop to funnel outside air to the air filter area.
Old 07-21-2004   #28
My cars already set up to have a Cold/Ram Air installed. :woowoo:
I have everything ready to go. I was also wondering is there significant benifits to building a Heat Shield around your K&N?
Any other suggestions?
Old 07-21-2004   #29
couldn't hurt, 8 million other people have made em for themselves
Old 07-22-2004   #30
Enes - here are some logs hopefully they'll take.
First one is 2-3rd gear pull Back when I first got my car up and running and it was holding 17psi. (or at least I think it was holding?)
Old 07-22-2004   #31
Here's a 3rd gear run from 2700-8,000rpms.
Old 07-22-2004   #32
Enes
Enes's Avatar
thx, i'll take a looky!!!
Old 07-22-2004   #33
Enes
Enes's Avatar
you are most likely going over 46#, i tought there was a limit in dsmlink at that and then you have to switch to the other format of reading.. did you read about that on their forums?
-E
Old 07-22-2004   #34
I haven't been on there boards in some time. I have the original version of DSMLINK V2 still.
I know Howie gave me the 1.02 verson or what ever it was. but I haven't swapped to it yet. (I was afraid I'd loose my old data)
-Brian
ps: I'm going through my logs now to find a new one of when my gaskets blew. I was seeing 50.3lbs/min but also noticed my boost was climbing to 25psi as well?
so somethings up. cause at 17psi I was seeing 45-49lbs/min but now at 25psi I'm seeing 50lbs/min
Old 07-22-2004   #35
Here are a few more
Old 07-22-2004   #36
Another
Old 07-22-2004   #37
another
Old 07-22-2004   #38
I think this ones the 50lbs/min (or it was the one before this one)
Old 07-23-2004   #39
Here are some logs of my S20G from the last time I was on the dyno.
Old 07-23-2004   #40
The last Pull we did on the Dyno
