Old 12-05-2004   #21
Pimpin Dsmstyle
Br0k3N
Pimpin Dsmstyle's Avatar
i dont even see where the IN hole is on top.... Ne one got a picture? And for that fact, i dont recall seeing the drain plug. I drove it last night, good as new man! lol.
- Josh L.P.
Old 12-05-2004   #22
Khadgar
Can't Actually Wrench
If you are talking about the fluid fill, the bolt is more on the side that it is on top, helps to have a funnel with a long tube neck.
Old 12-05-2004   #23
The fill plug is on the bottom near the plastic splash pannel. The pannel is actually kind of in the way. The fill plug is on the side of the tranny. It is on the intake side. You have to remove the intake and there is a 17mm plug. BTW, you will need a 24mm soccet to take off the drain plug.
I filled my tranny fluid today. I took the radiator out as I was doing a coolant flush and it was empty. I used to do the funnel way but it is easy to pour in the hole with the radiatior out. The funnel way took way too long for me to sit and wait. I am going to now pull the radiator each time. It will make me change the coolant at the same time and I will not get so pissed off at how long it takes with the funnel method. The fluid I had was sitting in the garage for a while which didn't really help the case though...
Old 12-05-2004   #24
Once again, why not just buy a cheap 5 dollar pupmp at checker??? Youd rather remove your radiator and just squirt it in? I dont get it. Maybe just that one time you change the coolant but not every time you need to add, refill, or redo the fluid.
Old 12-06-2004   #25
Maybe I will try that next time. Pulling the radiator was very easy for me today and it only took another 10 minutes vs spending another 20 minutes running over to checker and back.
