Old 12-08-2004   #21
PSI2HI
All in all do you thinks any of these factors are really going to matter for what this particular person is going to use them for? For say in a 1/4 mile pass your only going to generate so much heat and its not really going to dissipate or cool down when your 100% throttle the whole time. So for say aluminum cools faster but there is no point @ which there isn't constant heat applied to it. I could see there being a bigger difference for say a road race car where your not constantly @ 100% throttle. IMO honest opinion i dont see there being much of a diff between alum/SS for this particular application for the everyday user. On a racecar where you're looking for every last possible ounce then yeah maybe.
PSI2HI is offline   Reply With Quote
Old 12-08-2004   #22
Yea, it is a moot point anyways. Kinda like removing the coolant lines from your TB because you think it's going to make the air cooler.
Old 12-08-2004   #23
Raptor
ConArtist
Raptor's Avatar
That is true however if the conditions that caused it to get hot still exist, the alluminum is going to transfer that heat into the intake charge as opposed the the SS which does not exchange heat in the same fasion. If you are talking about running at the track, between rounds, there is adequate time to cool SS piping and the likelyhood of it heatsoaking is less. It takes longer to heat soak the pipe and even after it is hot, it still will not transfer that heat into the intake charge more than alluminum otherwise intercooler cores and radiators would be made from SS. Alluminum is much less expensive to manufacture which is why larger companies like APC and Injen make intakes from alluminum, they take manufacturing costs into consideration considering volume of parts and marketing to the masses. That and polishing SS is more expensive and you don't have the options to anodize in lots of pretty colors that the majority of our markets seem to like over performance even. Buschur's intake pipe is SS as well for the same reason's I mention, not for ease of manufacture, rather because it is better. As far as intake manifolds being made from SS, they can be, and it would be effective but the fabrication required to make a decent manifold that didn't look like ass would be cost prohibutive to too many customers and beyond the capabilities of most shops. In either material, I would want the intake insulated from the head to stop heat transfer to keep it from maintaining a higher temperature. I have actually considered making my intake out of SS because I don't have to worry about the cost of manufacture and trying to make the price attractive enough to sell to the public.
Quick Precision Racing, Inc.
"Always Raising the Bar!"
651-488-7774
Old 12-08-2004   #24
Raptor
ConArtist
Raptor's Avatar
Also, just like weight reduction, if the goal is to dominate, effects are cumulative. Not for the daily driver, but thats not who we market to anyway. If anyone was confused on this, we push to work more specifically on race type apps that care about getting every ounce as opposed to DD's. Keeping the entire intake charge system as dense and cool as possible should be the goal of any racer as well as (at least for drag racing) taking weight reduction into all areas to keep overall effect as much as possible. Depends on the goals, if average is okay, don't push for more and deal with the people that do take everything into consideration, they will be the tail lights you see
651-488-7774
Old 12-08-2004   #25
PSI2HI
Buy nitrous, it's COLD!!
Old 12-08-2004   #26
Raptor
ConArtist
Raptor's Avatar
I do like that idea!
651-488-7774
Old 12-08-2004   #27
If you're really worried about heatsoak on a pipe in which pressurized air runs through at Mach something, cover your piping with a heat reflective wrap. I don't think aluminum or SS makes one bit of difference on our cars.
I'll trade my SS pipes for matching aluminum pipes if someone's got them. But not some hokey Dejon crap.
Old 12-08-2004   #28
I am in total agreement with Mike on this subject. I am going to be making 2 SS intake manifolds very soon, the flanges are being made right now.
One thing I haven't seen as much on this subject is insualted IC pipes. I could see this helping a lot, but noone ever does it. Probably just because it looks kind of ghetto, but it definately would help.
Old 12-08-2004   #29
I can see both sides, and they both make good points.
Lord knows I can think about stuff, "over think" about stuff and go totally extreme at times. Poor ecoli has probably popped a few headache remedies since I started talking to him about turbos (sorry about that ecoli ). I think there are many factors leading to the correct answers for this.
Several things come to mind, first would be what is the purpose of the part in question?
Intercoolers are designed to maximize the air-to-air or air-to-water transfer of heat by ways of increased contact with the metal by way of turbulence which is purposely caused by internal design of the cores . I think it would be very important to take every bit of opportunity to help with that effect.
Intercooler piping is a means to move the air from one place to another. I'm sure that there is some effect from the different metals used, but in our applications, would we really see a difference? The air flow is so fast that there really is not much time/contact with the intercooler pipes to really make a difference. I would like to see somebody do a controlled test inviroment (Raptor?) to really find out. Most intercooler routing is really short. To see if there is a difference you would have tap and read temps at each end of each pipe under boosting conditions to find out. I would think the biggest benefit would come from just insulating the pipes with a reflective temp wrap.
As Raptor said, if the added weight kills the benefit from the increased efficiency, what's the point?
Old 12-08-2004   #30
Raptor
ConArtist
Raptor's Avatar
I am waiting now on a digital manometer so I can do in car on road testing of pressure drop, I could probably setup a twin IAT setup that is similar in design to check out the temp differences as well in real world situations.
The one thing about this that you have to always go back to is just the laws of thermodynamics, it is proven beyond question that aluminum is a better thermal conductor and SS is a better thermal insulator, the IC needs to be a conductor to transfer heat in either air to air or air to liquid configs, the piping is a conduit for moving the air and should be an insulator so it isn't effected by external thermal impact and if it is, a metal with better insulating properties will transfer less of that heat into the internally moving air regardless of the temperature of the pipe's material. If it effects the air moving through it to a noticable degree is the question I think is most relevant. I will find out so there is no longer a need for wonder. For now I am still going to lean toward the side of logic and thermal dynamics and believe that it is worth taking the extra steps for the best possible scenario.
651-488-7774
Old 12-08-2004   #31
For the little bit of difference in cost, why not do it the right way and use SS? As far as weight, we are talking what, 2 lbs. difference for all of the IC pipes? Even if the intake temps are 1 degree cooler it would probably make a bigger difference than 2 lbs.
Old 12-08-2004   #32
95tsi
95tsi's Avatar
Drives: a pos
I've had good luck with my Hahn front mount with my own custom piping. Good price and has worked well for my setup. I'm not going for super crazy horse power so I didn't feel like spending big dollar for an intercooler.
As far as piping, I had the Archer UICP and just tied into that. In my opinon, the speed of the air in the intercooler is moving so fast that the actual material used for the piping won't make a siqnificant difference. The piping I made, I simply had powdercoated black and put it in. Like I said, the cold side is a bit longer and utilizes the Archer UICP, however, it dosnt' run directly next to the engine(pro's and con's).
The choice is yours as to what you use. I'm guessing that unless someone specificlly says one company sucks horrificly, most places seem to make a descent setup. Just find somthing that works close to the budget you have.
Old 12-09-2004   #33
One thing that will probably really effect how hot the air is entering your intercooler is if the piping exits the turbo and goes right in front of the O2 housing/DP. If it does it will take the heat radiating of it and absorb it. My IC piping goes the other way, this setup might be longer but I think the temp differences would be pretty drastic compared to having a "short route" piping system that passes right next to the really hot exhaust. (Unless you insulate the piping in that location.
Old 12-09-2004   #34
Cool, lets use concrete then....oh wait, it does make a difference. Cores are made from aluminum for a reason.
On another note, piping and intake manifolds should be made out of carbon fiber
Old 12-09-2004   #35
you can get some bomb-diggity cool fibber intake mannis for honduhs, someday maybe our cars will be cool like them
Old 12-09-2004   #36
Yeah...and they actually work really well too.
Old 12-09-2004   #37
Uhh, I did that three years ago, I didn't notice any real difference, but I wasn't exactly testing down to a 1 horsepower difference either. I plan on testing it again with my new setup this spring just for grins, I don't think it'll make any real difference except maybe off-idle.
Old 12-09-2004   #38
Raptor
ConArtist
Raptor's Avatar
We can guess and speculate all day as to how effective this type of stuff is all day and it won't answer the question I have my beliefs on it, obviously others have different ideas as well. I will start testing this stuff in January so the answer isn't that far off. I will be able to check anyones setup on their car so the guys who want to try insulating wrap etc will also know how effective thier setup is, I will make sure I have a duplicatable course to test with so the results can be compared fairly as well. It is worth it to me to do this in the quest for more power so I want to get the most accurate testing procedure possible.
So just for the sake of discussion, what do you consider a worthwhile gain? 1 degree of difference? 5? What would it take for the guys who are serious about power on this board to justify the difference in cost/weight for SS over anything else? And why?
651-488-7774
Old 12-09-2004   #39
95tsi
95tsi's Avatar
Drives: a pos
Obviously some materials work better in certain locations. I'm just trying to help out with the original question posted as to what to go with for an intercooler. I don't recall seeing in the original post as to find somting with carbon fiber piping or go with a light gauge steel. Me personally, I can't justify spending $500 more for a horespower gain of maybe 5-10. Sounds like the guy looking for the intercooler to use dosn't want to spend a fortune on his setup to run some descent numbers. If you plan on running your car into the 9's then by all means make your intercooler pipes with carbon fiber to match your bling bling manifold.
Old 12-09-2004   #40
SuperSleeper
SuperSleeper's Avatar
Drives: 2012 Audi S4
I would think it would need to be upwards of 3 degrees to make an impact, in performance or in information. But that is such an ambiguous figure... what does 3 degrees, or 5 degrees, or whatever it is, mean in the grand scheme of things? Ultimately the aspiration is more HP and quicker times... the only way to get the full satisfaction and understanding is to test it on the track.
