Old 10-21-2005   #21
Re: Questing about crankwalk and my clutch system
Originally Posted by clean2g
To: Onefast99gsx
Was your clutch pedal really hard near the floor and felt like something was under too much tension, and every time you adjusted it, it wouldn't really do anything? I think I have the same problem but I'm not sure, I've tried to adjust it but I don't know if I'm doing it right because nothing changes really after I make an adjustment.
Does your car have clutch disengagement issues?
It sounds like your clutch fork could be bending/bent. What is happening is you are reaching full throw of the hydraulics system and actually pushing the clutch fork against the bellhousing. Since the fork is bent (usually where the TO bearing mounts, sometimes between the fulcrum and the slave cylinder) it isn't making its full travel to release the clutch.
