View Poll Results: What cams are good with 14B's/16G's?
FP cam 1 3 5.17%
HKS 264/264 12 20.69%
Crower 412’s 0 0%
FP cam 2 2 3.45%
HKS 272/272 16 27.59%
Crower 413’s 0 0%
Crower 414’s 0 0%
Crower 415’s 0 0%
I don’t know what the fuck I’m talking about but I wanted to vote. 25 43.10%
Voters: 58. You may not vote on this poll
Old 02-28-2005   #1
MustGoFaster
MustGoFaster's Avatar
Drives: A big dirty V8
CAMS!!! Best for 14B/E3 B16G?
Well with my WTB thread posted and all the controversy, it look like this is necessary. Here is the basics on what I have and what I want.
Car: 1992 Galant VR4
Rebuilt stock motor, pulled 160-160-160-157 for compression #’s with my old head
DSM SMIC
More fuel than I will EVER need
I use an EEPROM burner to tune, no AFC
Currently has a 14B, ported EX side with a 34MM flapper
2.5 O2 elim, 3" the rest of the way
4 Bolt, Excedy 1900 clutch
Wet 75 shot, NX
PLX wideband
Standard gauges (boost, EGT, OIL pres, oil temp)
Will be getting:
Ported 2G head, with a modded 1G intake mani
Cams
EVO 3 16G when the 14B falls apart.
Goals:
While it is fast, and I want it to be a bit faster, but IT IS NOT MY RACE CAR. I drive it every day in the summer. I am staying with a small turbo because I don't want to deal with getting a bigger IC (even though I should when I go to the 16G) and it is also nice to have power from down low for merging, with out going down to 2nd gear. (around 3K)
I have driven a car with 272’s and a laggy turbo. John’s car, back with the 60 trim. Did I mind it, no. Just not what I am going for. I don’t think I need them.
Idle quality isn't a huge issue, 272's are fine, but will they put the power were I want it?
My reasoning:
Since I am going to have a small turbo, I might as well have cams that don’t move the power band to somewhere the turbo isn’t going to make power. With a 16G you get all of 1HP more, with significant losses in the low end (see above) if you go for 272’s or the like. A bit more many be possible with the EVO 16G, but who knows. Idle quality isn't a huge issue, 272's are fine, but will they put the power were I want it?
So what should I get AND WHY?
