Old 05-26-2005   #21
BKs50trimGST
Post whore
Send a message via AIM to BKs50trimGST
Re: What to do next>>>
wait, rewire the fuel pump??? and yes, i will be getting dsmlink very soon.
BKs50trimGST is offline   Reply With Quote
Old 05-26-2005   #22
You have a built motor and a 50 trim but don't know what rewiring your fuel pump means? Are you aware of the main requirement you car must meet in order to run DSMLink?
Old 05-26-2005   #23
wideband + dsmlink
Old 05-26-2005   #24
Id suggest going back to stock and then working your way back up. You obviously dont know alot about dsms and you just bought one that was all modded up for you. Either learn a whole lot about tuning/dsms and how things work or you will learn the hard way like you did when you fried your motor a while ago.
Old 05-26-2005   #25
Preach on Peter!
Old 05-26-2005   #26
DSMLink, wideband, bigger fuel pump, fuel pump re-wire, bigger injectors, AFPR, bigger FMIC, port the 2g head to match the 1g intake manifold so the airflow is not hitting that flow restriction, ARP headstuds, GT35R turbo, HKS 272/272, adjustable cam gears, etc, etc, etc.
