Old 08-31-2005   #21
Re: head issues
well number 1 cylinder, all the timing marks should line up. Otherwise screw the hose into the hole, and put your finger over it, when you feel air pushing against your thumb, your on the compression stroke. Or put a rod down the hole, etc..
You don't have to be AT TDC just on the comp stroke, if the piston is more than 1/2 way down (or up rather) it could blow back down with air pressure, just find a way to make the motor stop moving (aka rachet/breaker bar on crank pully).
Old 08-31-2005   #22
Re: head issues
Or you could put the car in gear with the e-brake on!
Old 08-31-2005   #23
Enes
Enes's Avatar
Re: head issues
The dsm is in its natural habitat, on jack stands with wheels off ground.
Old 09-29-2005   #24
DSMDragn
Send a message via ICQ to DSMDragn Send a message via AIM to DSMDragn Send a message via Yahoo to DSMDragn
Re: head issues
and i thought its nature habitat was on the back of a tow truck
1992 Eagle Talon non turbo 2.0 L
AKA (P.O.S) aka always busted aka i'm getting it fixed
DSMDragn is offline   Reply With Quote
Old 09-29-2005   #25
Re: head issues
Nope, up here all of our cars hybernate in the summer on jackstands. Then in the winter, they hybernate on ...
....jackstands.
Old 09-29-2005   #26
DSMDragn
Re: head issues
So what your telling me is i need to invest in a good set of jack stand because my car is going to stay there 90 percent of the time :P
Old 09-30-2005   #27
Outlaw1
Resident Redneck
Outlaw1's Avatar
Re: head issues
Originally Posted by Enes
So how do i determine that Cyl1 is on compression stroke, ?
same should apply to #4 at the same time correct? or are they not at the same stage?
-E
When #1 is on the compression stroke, #4 is on the exaust stroke.
Did you compression test? Is that why you're doing a leakdown?
'07 Z06 Black/Black 2LZ
10.48 @ 136.86 w/1.65 60'
Old 10-04-2005   #28
KcGsXrated
KcGsXrated's Avatar
Drives: 93 Talon Tsi
Send a message via AIM to KcGsXrated
Re: head issues
If everything on the timing side is completely lined up, (including the crank) I couldnt see how I'd be difficult.
~~DSK~~
Casey
93 Eagle talon Tsi fwd auto
KcGsXrated is offline   Reply With Quote
