Go Back   MitsuStyle > The Homefront! > The Parking Lot - On & Off Topic > Video Forum
Old 08-30-2005   #21
Re: Shep goes 8.1@177.6mph at ATCO
Originally Posted by Super4x4Duty
To give you an example, I've gone 9.60's @ 138 in a Mustang with a 1.34 60' on a true 10.5 tire and that's not a record by any means. If he could get his first 1/8th mile sorted out...watch out.
It's a little easier to pull a good 60' with an auto though.
Old 08-30-2005   #22
You can't heat up the tires in an AWD either.
Old 08-30-2005   #23
F1 style tire blankets.
Old 08-30-2005   #24
That is fast. I will order up a 78mm turbo and direct port nitrous kit, then I might have a chance.
Old 08-30-2005   #25
Onefast99gsx
Does shep have the stock tranny or is he running something else like those BullDogs or something?
Old 08-30-2005   #26
He is running a GT42, so it is probably a 74mm or the less common 76mm version.
Old 08-30-2005   #27
He has a Shepracing dogbox in it. Last year he was running a Shepracing modified stock one.
Old 08-30-2005   #28
78mm is the class limit. NDRA has more open rules for pro 4 then NHRA. So I thought the 74mm was the limit and you could only run one poweradder with methonal. Now I can try some nawz with my high boost on meth, it will be fun.
Old 08-30-2005   #29
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
His tranny costs 3300 and you can get 300 off for a core.
7/25/09
Old 08-30-2005   #30
Is that 3300 for the dogbox? I should find out befor I order one.
Old 08-30-2005   #31
slowbubblecar
Big Turbo Monster
Drives: GTS and E55
The same one he uses. That is what I planned on ordering up anyhow. I asked how much for the race box they use in his car and that is what he replied.
7/25/09
Old 08-30-2005   #32
Onefast99gsx
$3300 for a tranny? Holy Shit! I'd convert to RWD with a glide in it before i'd shell that out. I wonder if he uses a stock dsm rear end in it. I would assume the drive shaft is not stock neither are the 1/2 shafts?
Old 08-30-2005   #33
Wizard
Stock pumpkin, Driveshaft shop rear axles and 1 piece carbon driveshaft.
Wiz
Old 08-30-2005   #34
There are always changing the rules to try to keep the cars closer. They made Rau go down to a 78mm from an 80mm in the middle of season, to try to slow his car down.
Old 08-30-2005   #35
his transfer case is some limited run custom deal too isn't it?
Old 08-30-2005   #36
Yup, DSS modded xfer case and output shaft.
Shep runs a 4-speed dogbox, most people aren't going to be ordering that.
Old 08-30-2005   #37
TGPilot
TGPilot's Avatar
Man what a fun ride that would be!
Old 08-31-2005   #38
Outlaw1
Resident Redneck
Outlaw1's Avatar
Who said it was an auto? I've gone 1.29 sixty foots with an auto and 10 wides.
Just wait until Shep gets ALL his power to the ground. Sick.
Old 09-01-2005   #39
I should be ordering all my drivetrain in about 2 weeks, and the cage should be going in over the next 2 weeks also.
Old 09-01-2005   #40
slowbubblecar
Big Turbo Monster
Drives: GTS and E55
You should have kept that and said screw it to the dsm
7/25/09
